Two questions- Alignment issues/car locked with smart key in the car
Brutal, the 08 XKR has caster and camber adjustments in the front. The lower control arm is where you make a camber adjustment. The wishbone, boomerang looking arm in front of the lower control arm is the where the caster adjustment is. So yes there is front camber and caster adjustments on his 2008 XK
Received 2,192 Likes
^^^^^^lol, you know I totally glossed over the year we are discussing and was thinking about the 06 and older setup even though we also are talking smart keys...
What would I do without someone to keep me in line
Yes youre correct. and since Im now thinking of the correct years.... If you increase the caster, even past recommended spec for more positive caster, this will reduce wander..... also On the locking the key in the car I AM reffering to the microswitch in the outer door handle drivers side not the latch.......
msdg137
09-16-2015 06:24 AM
Andrew McVey
16
08-27-2015 07:21 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
