Typical Cost for brake fluid flush and change
#41
Received 2,263 Likes
#42
#43
#45
#46
Rich - if done right only one litre is needed... I used the ATE 706402 Original SL.6 DOT 4 Brake Fluid - 1 Liter... and 2-4 pints of Smithwicks is recommended soon after
https://www.amazon.com/ATE-706402-Or...te+brake+fluid
richzak (08-19-2016)
#47
#48
I bought 2 liters just in case I run short. Bought the Pentosin 1204116 Super Dot 4 Brake Fluid, 1 Liter by Pentosin via Amazon. Solid 5 star rated.
Gets done, Tuesday.
#49
#50
#52
I am not sure what the Jaguar dealer will use for the flush.
I am using Pentosin Dot 4 Super which runs about $13.00 per liter.
The 2009 Jaguar XKR uses the Dot 4 Super brake fluid, which is different than plain Dot 4.
https://www.amazon.com/Pentosin-1204.../dp/B007PCQCIU
#53
Panthro (08-30-2018)
#54
Received 2,012 Likes
scottw
05-19-2016 01:43 AM
