Ugh, my first real problem, Even-Numbered Misfires RESOLVED
#41
My question relating to whether there were 2 crank position sensors comes from my old Ferrari days. Their V8's with 2 distributors would have 2 crank pos sensors. One for each bank. As for engines with COP I would believe there is only one CPS but didn't know if each bank were triggered separately.
Cee Jay (07-20-2018)
#43
Alrighty then..... that X250 forum OP had the same symptoms as I do, but the opposite side. He found out that ONE bad injector, stuck open, can flood that one cylinder causing all that fuel smell that I smelled. And in doing so, reduces the rail pressure enough to cause the OTHER three injectors to have insufficient pressure to, well, inject. That guy had one injector replaced and all was well.
SO, there's another possibility for my whoppin' good times.
#45
I sort of mix fuel 'qualities' (actually 'additives', since they all come from the same pipe) dependent on where I am at the time. Probably a half-'good' and half 'normal' type of situation.
I do probably more than not have shorter trips of less than 10 miles. Trips over 15 miles are not common, but do happen every so often, so there is a distinct possibility of carbon.
shemp (07-20-2018)
#46
Cee Jay (09-04-2018)
#47
I pulled off the cap and the odor of a refinery hit my snout. So now after I get the injector(s) swapped, I get to do an oil change. wwweeeee........
#48
That is sounding more and more like my experience in the XJL, only I had to have the whole rail replaced, not just the injectors. I hope your experience is less painful and less expensive than was mine.
Cee Jay (07-21-2018)
#49
You know all this but may overlook in the fog of it all.
Keep an eye on that gasoline in the oil. It can add significant volume to your oil. My double barrel had the secondary butterfly sticking open and the oil I pulled out of there was 2 qts above capacity.
It will swell up newer seals.
How abouts taking the car (on trailer) to a fuel injection cleaning service- you have nothing to lose, and other injectors to save.
Since you have this problem, I suspect you dont worship PEA detergent. It really does dissolve carbon and the only thing effectively known to do so.
Do you know these guys. Fuel Injector Service-Fuel Injector Cleaning, Fuel Injector Testing
#50
HillmoorPete (07-28-2018)
#51
Absolutely none of the gasolines have any real detergent in reality.
My truck has a funny injection system, it has 8 injectors spraying in the intake where each intake feeds the cylinders.
So its one of the few engines where you actually get to see the results gasoline or its cleaning ability.
I have only used top shelf and religiously run PEA through it on top of all that.
When I took the engine apart I was shocked to find how much sticky varnish there was.
It took 2 days of soaking in acid and degreaser to get it clean.
I believe fuel cleans less than it leaves gum and varnish.
Will post pics- they are worth a thousand words
#52
Completely agree with you and go beyond....
Cee Jay, what's the status?
#53
Basically what they are saying is that while all retailers source gasoline from the same suppliers, each brand has their own proprietary blend of additives and some are better than others at deposit control.
#54
What I find interesting is old school diesels with mechanical pumps don't suffer from this condition. Granted the injection timing could go off if one injector lost spring pressure and popped off early but they are generally million mile reliable, far more than electrical coil fired ones in diesels of gasser's.
#55
Anyway, now that I can ALMOST speak coherently, I'm going to contact that semi-local indie guy and see about towing this monstrosity to him. Screw the dealer, ESPECIALLY Ken Garff Downtown. They SUCK.
I sort of feel like a loser because I'm positive that I'm quite capable to do the fix myself, but my debilitating back pain makes it nightmarish to stand for too long, and then add the leaning over the engine bay and I'd be crying within an hour.
Oh well, money ain't nuthin' but a thing.
About that 'top tier' fuel keeping the intake clean......... how would it when 'gas' doesn't enter the intake? That's only air in there, since Direct Injection. Sure, some residual mixes, both burnt and unburnt may manage to squeak up above the valves, but not much.
#56
#57
I was adding from empirical evidence- dont be surprised if the cleaning claims of any product falls waaay below expectation
They capitalize on human emotion. By saying in 1000miles they were completely able to reverse accumulation on intake valves.
We naturally draw conclusions that its doing wonders elsewhere too. Nope.
(and in our case its not even touching the intake valves)
shemp (07-26-2018)
#58
Then again, I've used supermarket brand regular 87 Octane with a dose of Techron every 4-5k miles in my 2002 Yukon since new (5.3L). 170k miles. Mobile1 oil every 5-6k. Still runs strong and smooth.....
Feel better Cee Jay. We are all patiently waiting on the cause and fix of your issue so get on it
#60
I have a slot at that shop for Tuesday. They have a former Jaguar tech there and when I talked to him he just babbled off a WHOLE bunch of stuff about everything Jaguar that I'd never even heard of before. A twenty second conversation pretty much impressed the hell outa me, in regards to Jag knowledge.
Therefore, more to follow on .... Thursday? Maybe even Wednesday, at least for the diagnosis.
