Upgrading injectors where to find? 4.2sc Jaguar XKR
Planning an e85 full conversion. Any info on which injectors can be used will be greatly appreciated!
07-09 XKR
07-09 XKR
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
https://www.google.com/search?q=why+...obile&ie=UTF-8
__________________
your realy asking why? It's only the most common power adder on forced induction cars these days
Very interesting! Was aware of Indy cars and speedway bikes on alcohol. Very high engine performance.
But E85 was hard on alcohol intolerant road car components except Flex fuel cars so personally never considered it. And I don't think it is available locally anyway. Please keep us posted on your higher performance pursuit.
__________________
V7Sport (03-13-2021)
Thank you! How about the capability of the stock fuel pump?
__________________
I am not very familiar with 4.2 single pomp ( returnless fuelling system), but what I know from 4.2 TS installs, the pump has some limitations and you can not control the duel pressure. I have rails from 4.2 but the have modded with return line and 2 x 255 Walbro. KB Boost-A-Pump can be used to increase pump capacity at WOT. My injectors are quite big ones... But big airpump needs a lot of fuel 😎 E85.
MarkyUK (03-14-2021)
I tried testing the capability of the stock injectors and I think they are running out of room at 34% ethanol mixture. I can control the fuel pressure in the ECU but it appears they adjusts on demand per AFR requirements anyway or I'm misunderstanding on how it works. I have seen it as high as 75 psi at wide open throttle and at around 44 PSI at idle.
Wot = base pressure + boost
Thanks, I love the persuit of power ! If you follow my threads ,I have one of the highest dyno 4.2 sc xkr cars around as well as fastest 0-60 and 1/8 mi times, also just finished tuning the fastest 5.0 XFR on the world recently , so far at 11.4 but likely it will be even lower than that soon
Did you not run these times at a actually drag strip
I guess I have to look into that more , but I can't be making 31psi of boost so I wonder how that works
__________________
Steve I got nothing to prove to you I can tell you this though , I go drag racing regularly And most of my buddies have Draggy devices as well and Track time slips are always nearly identical to Dragy time slips down to hundreds of a second. By the way most magazines use these sort of GPS devices for testing and not the actual track slips.
__________________
steve_k_xk (03-14-2021)
There is no way I have 20psi of boost more like 11- 12, so I wonder how that works out
__________________
