Upper control arm ball joint bolt
d a (05-28-2020)
d a (05-28-2020)
The following 3 users liked this post by Sean W:
OK crew, got-er-done! Rechecked the ball joints and flogged it for about 50 miles around town. Job wasn't tough at all, biggest deal was waiting for the boots and nuts to finish up. A couple of observations though:
1. Not sure of the correct size for the ball joint shaft hole, but a #5 allen worked for me best.
2. Found the boots on Amazon to meet my shadetree measurements, but 15-30-22 seemed to work good for me. I'm sure these are the original control arms.
3. Found a cable from the chassis to the rear of the brake caliper that I wasn't sure of (see pix), problem was it was missing on the passenger side caliper. Sort of worried about that. Never noticed any driving effects or got any codes. Checking the Svc Man for that.
Finally, noticed what I thought was a small oil leak a couple times on my garage floor after my trips, but seems to be a little more than I thought sitting in the bottom body panel when I checked further. Couldn't find any apparent source yet, just hope it's not too bad. I'll check "oil leak" posts and I guess back to the manual before I start a teardown. All n all enjoyed the work and definitely enjoyed the "test drive" afterwards. Thanks to all for the tips and help. I'll keep you posted on the "leak".
Trying the tie strap per someone's post, didn't seem like it would stay tight, we'll see.
Found this on the drivers side caliper. There seems to be some cradles for a cable on the passenger side but noooo cable.
d a (06-20-2020)
wouldbeowner
09-04-2020 09:54 PM
muttony
08-17-2018 03:45 PM
hawaiiansurfster
01-01-2013 07:13 AM
