USB Issue/ Parking sensor screen
I reckon the battery is suspect. Since you live in a colder climate, I’d go with higher CCA, 900 plus. Amp hours are recommended to be 90 but it’s not that important unless you leave the car electrics on frequently without the motor running or leave it off the CTEK for extended periods. I believe most X150s were fitted with flooded batteries due to the charging profile of the alternator/BMS. For a proper fitment you’ll need a H8 group size.
Hi all, jutst to follow up, battery is discharged badly, he is somewhat surprised I haven't had any starting issues.
He is ordering me a new one and he thinks I should be able to get a new one under warranty, so even better I will see if this fixed anything
The battery was more charged this morning and I was able to get the phone to sort of connect. So I am thinking this is all power related.
Oh, and I am going. With a flooded battery. I will tell you guys the type etc when he gets it in
Thanks so much marty, I am going to the battery shop where my buddy works today to have a look and see what other options exist. Interestingly now, interstate recommends an AGM battery as a direct replacement for this car. It can't be this hard to figure out the right battery there are no extra electronics added into my car that I am aware of as a note.
Having said all that, there are plenty of owners here who ignore the TSB from Jaguar without issue.
Doesn't matter whet interstate recommends. Jaguar recommends replace like for like on their 2010 onward, so if you had an AGM as OEM, use AGM. If you had conventional lead acid battery equipped with you OEM, use that. It has to do with the type of alternator they install I suspect.
yep certainly will help and probably just fine for another 6 years or so.
So I replaced the battery with a new Interstate. I charged the battery overnight (green on the ctek) and installed it this afternoon. Same issues. I am going to try a few new things, another set of USB sticks, i have unplugged my charger from the cigarette lighter.
The issue seems to happen after longer stops, not really sure why. In the plus side, I finally got my phone to pair with the car again.
Oh, and an I teresting fact, my (old) battery that read discharged last week, now reads full charge after being removed from the car... Something odd is happening I think hmm. Maybe a parasitic draw?? No clue
I should note, that when I put in the new fully charged battery, everything worked great at start up.
#28
Sorry for the confusion, I charge the car through a ctek comfort indicator port in the trunk. The cigarette charging is for my phone. I am just saying that I pulled out the charging unit. It has a light on it that stays illuminated for some period of time, so maybe that is contributing to some parasitic drain? Who knows.
#30
So here's a little trick that can work on checking initially for parasitic drains. Use an infrared thermometer and point it at the exposed fuse box after shutting down. You can sometimes see an illumination. Tells you where to start vs pulling fuse by fuse then checking the battery.
Will have to do some digging
#31
Car takes about 30 minutes to shut all components down so you want to wait for that, don't lock it and keep the FOB away then check each fuse box. Doesn't always work but sometimes you can see it. But you can just test it with the car on and running to @ the CJB or AJB, whichever is more convenient to see if your IR thermometer shows anything lit up.
I haven't done it myself but I did watch a friend do it on one of his cars and a fuse did show a draw. The fuse was for the door light though so he ended up doing it the old fashioned way....one fuse at a time.
MarkyUK (06-13-2020)
#32
XKGuy
11-02-2013 06:56 AM
