V1 Blendmount & MirrorTap
I just installed my old faithful Valentine 1 radar using the Blendmount PN: BV1-2114 mount and MirrorTap power connection. I decided to go this route as I want to keep my XKR-S as stock as possible and this setup is easily removed without leaving a trace. I know there are better hardwired detectors out there but I also don't want an installer tearing my car apart to run wires and mount modules etc. The V1 has always served me well and saved my butt a bunch of times. The install was very straightforward - it only took about 10mins to complete after I knew what I wanted to do. The MirrorTap was also a snap to connect. The 2 wires matched my mirror hardness so took all the guess work out of it. Here's a few pics.
Hmmmm - MirrorTap looks interesting. But why does it need an 8-foot cable (that's the HT-1096 which they recommend)? Presumably the cable goes into the mirror electronics, which are only a few inches from where I'd mount the V1.
I think I'd probably stick with the suction mount, which I position above the mirror to give the greatest range and make the V1 less obvious.
Ngarara- its 8 inches not 8 ft. And that is the total length. Most of the cable is hidden inside the mirror plastics so only about 3.5 inches are exposed.
Correct. You are referring to the hardwire kit. I went with the MirrorTap power cord which is basically plug & play.
You just push the two pins into the corresponding connector. Here's a pic from MirrorTap's site. Our Jags have a slightly different setup. Refer to my earlier pics for what the connector looks like. You cant see any of the wires once you put everything back together so its a very clean install.
MaximA (03-11-2014)
Also times the $ by however many other cars you drive... I can pull the V1 in 5 seconds and plug it into the JCW or Evoque and have the same protection.
MaximA (03-11-2014)
I believe I used the MT-1009 but any of the MT-1000 Series will work. It may be better to go with a longer version to provide greater flexibility when routing the cable. Any excess can be hidden in the plastic casing behind the mirror mount.
Don't buy this one its 8 feet long and not the mirror tap. I just made that mistake, just get the mirror tap that works with your detector.
I just bought this one:
https://www.cobra.com/products/cobra-iradar/s120r
Totally stealth, feeds all info through your phone (which I already have installed in my former ashtray) and totally DIY install. For $300 I figured I could try it.
MaximA (03-13-2014)
MaximA,
I recommend going with either MT-1012 or better yet the MT-1015. These will give you more options when routing/hiding the cord. Let me know if you need further assistance.
Good luck!
Hamish.
