Vacuum leak / cracked inlet
Old 01-15-2017, 02:29 AM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
Default Vacuum leak / cracked inlet
Just wondering how durable these plastic manifolds are it appears I might have a hairline crack in the underside of the inlet manifold (hard to inspect as throttle body is blocking view)
Old 01-15-2017, 10:27 AM
britannia's Avatar
Vacuum leak should show up as increased idle speed and/or code message on your
reader; otherwise it might just be mold line on plastic............
If no symptoms you should ignore it or coat 'hairline crack' with epoxy applied with a Q tip.
Hope this helps,
Cheers, Adrian
Old 01-15-2017, 02:13 PM
steve_k_xk's Avatar
Idle speed the same and no codes present however there is a nasty hiss so yes it does appear to be the seam on the inlet
Old 01-15-2017, 02:41 PM
Received 4,458 Likes on 2,427 Posts
Get a can of MAF cleaner and spray it at the suspect location with the engine idling, if no change in revs, no crack...
Old 01-15-2017, 02:54 PM
steve_k_xk's Avatar
I tried spraying with a water bottle but couldn't get the liquid close enough to the suspected area
I'll try with carby cleaner and a plastic tube to direct the spray see how that goes
Old 01-15-2017, 03:01 PM
I suggest MAF cleaner because it's not aggressive to paint, plastic, etc and leaves no residue.
guy (05-31-2017)
Old 01-15-2017, 03:20 PM
amcdonal86's Avatar
Is it similar to this hiss? I was told this is normal.
Old 01-15-2017, 03:27 PM
That's right, you can normally hear a hiss from the PCV system, on the supercharged cars anyhow (I have not listened for it on a N/A engine), my XJR has that hiss.
Old 01-15-2017, 03:37 PM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
Brake cleaner or Engine Starter Fluid also works. Less harmful than Carb Cleaner.
Old 01-15-2017, 08:22 PM
steve_k_xk's Avatar
That's the noise boys.. gezz it sounds terrible
Old 05-30-2017, 09:27 PM
jahummer's Avatar
Received 2,380 Likes on 1,490 Posts
I just noticed my PCV making the same noise as Alan's, pressing on the hose fitting lessens it to some degree and disconnecting it causes the motor to run rough. Don't know why I never noticed it before...
Old 05-31-2017, 12:47 AM
They all hiss...
The following 3 users liked this post by Cambo:
amcdonal86 (05-31-2017), DannyJ (06-30-2019), Queen and Country (05-31-2017)
