Which vacuum pump are you using for oil changes?
Sorry, they are just some hoses and such that I had laying around the shop. The major problem was the heat of the extracted oil. If you get the oil warm and not HOT, you'll probably have better luck. Cold, it wouldn't suck much at all.
McJag222 (08-13-2023)
My question was aimed at whether thorough cleaning (as recommended in the User Manual) is absolutely necessary for the continued correct operation of the Mityvac or if emptying alone is sufficient. Your first reply to this suggests you've not had any issues just emptying it .......
Received 3,209 Likes
I ONLY intend using it for draining engine oil.
I have used it about 10 times now, manually emptied it every time, never once bothered to clean it and never had a problem with it.
Unless you intend to use the pump to fill instead of extract I see no point in cleaning it out as that achieves four fifths of f-all.
In post #17 I wrote that I'd just purchased a Mityvac 7201 and I appreciate the cleaning advice received in replies.
It was from Amazon. The first one arrived with a broken clip on the top of the pump. The replacement arrived today ..... also with a broken clip on the top of the pump.![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
I'm now going to use Cee Jay's solution but with one difference. It WON'T be sourced from Amazon.
benters
03-19-2020 09:03 AM
Staatsof
05-27-2015 03:35 PM
