Which vacuum pump are you using for oil changes?
Old 08-13-2023, 09:15 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
Originally Posted by SDCR_XK
I am leaning towards this one, but not sure where to source the new hoses, and exactly which ones you got. Please share...
thanks.
John
Sorry, they are just some hoses and such that I had laying around the shop. The major problem was the heat of the extracted oil. If you get the oil warm and not HOT, you'll probably have better luck. Cold, it wouldn't suck much at all.
McJag222 (08-13-2023)
Old 08-14-2023, 02:42 AM
GGG is offline
Received 16,851 Likes on 12,186 Posts
Originally Posted by jahummer
Surely it would be easier to have one for filling only, if needed, the effort required to clean it to avoid contamination of fresh fluids isn't worth it.
I ONLY intend using it for draining engine oil.
My question was aimed at whether thorough cleaning (as recommended in the User Manual) is absolutely necessary for the continued correct operation of the Mityvac or if emptying alone is sufficient. Your first reply to this suggests you've not had any issues just emptying it .......
Old 08-14-2023, 04:30 AM
OzXFR's Avatar
Received 3,209 Likes on 2,366 Posts
I don't have a Mityvac instead I have a cheapish manually operated Chinesium pump I bought several years ago, similar to this one: https://www.ebay.com/itm/27490863263...Bk9SR7rk47W-Yg
I have used it about 10 times now, manually emptied it every time, never once bothered to clean it and never had a problem with it.
Unless you intend to use the pump to fill instead of extract I see no point in cleaning it out as that achieves four fifths of f-all.
The following 2 users liked this post by OzXFR:
Cee Jay (08-14-2023), GGG (08-14-2023)
Old 08-14-2023, 08:16 AM
GGG is offline
Originally Posted by OzXFR
I don't have a Mityvac instead I have a cheapish manually operated Chinesium pump I bought several years ago ...... I have used it about 10 times now, manually emptied it every time, never once bothered to clean it and never had a problem with it. ......
THANKS. That's what I hoped to hear.
Old 08-14-2023, 11:36 AM
White Bear's Avatar
I only ever use my mityvac for evacuation, never used it for filling, so have I never cleaned it. Re the hoses collapsing while evacuating, the oil is obviously way too hot. To aid evacuation you only need warm up the engine, this will speed up the process, but it’s not necessary.
GGG (08-14-2023)
Old 08-20-2023, 10:10 AM
GGG is offline
In post #17 I wrote that I'd just purchased a Mityvac 7201 and I appreciate the cleaning advice received in replies.
It was from Amazon. The first one arrived with a broken clip on the top of the pump. The replacement arrived today ..... also with a broken clip on the top of the pump.
I'm now going to use Cee Jay's solution but with one difference. It WON'T be sourced from Amazon.
The following 2 users liked this post by GGG:
Cee Jay (08-20-2023), kj07xk (08-20-2023)
Khan
06-16-2023 10:41 AM
etypefancierjr
E type ( XK-E )
07-26-2022 09:47 PM
Paul Mawson
04-22-2020 04:59 PM
benters
03-19-2020 09:03 AM
Staatsof
05-27-2015 03:35 PM
Quick Reply: Which vacuum pump are you using for oil changes?
