Variably stinky AC
It's hot and dry out here in the desert and the AC is on a lot.
I've noticed a bad smell from the AC.
It is highly variable as to when the smell starts.
Sometimes it happens immediately on turning on the car, sometimes the air will start "clean" and then turn smelly, and sometimes it does not occur at all until the car sits in the sun and the interior/ exterior heat up.
Anyone noticing something similar?
Any suggestions? (Unfortunately "popping into the dealer" requires a 110mi drive - each way...)
Received 2,263 Likes
doctock993 (06-22-2013)
Received 9,007 Likes
Hey therer, its a common issue, especially if the AC either isn't used at all generally or infrequently.
There's a build up of bacteria which loves the moist warm environment and can grow quite rapidly. It can smell like a combination of rotten eggs / veg, smelly socks etc etc and is generally really unpleasant.
If left it can and will get into the fabric of the car making it almost impossible to remove.
Get yourself a replacement cabin filter if fitted and replace the old one.
A can of AC refresh treatment whilst running the system on full blast, cold air recirc for 10 minutes or so should disinfect the systme and leave a lovely lemon fragrance within......all good.
doctock993 (06-25-2013)
Ozzy_UK
45
02-19-2019 02:05 PM
