VelocityAP XKR Tuning
Hi Guys,
We have a bit of a thread going on over in the F-Type Forum on our tuning capabilities: https://www.jaguarforums.com/forum/f...8s-v8r-158091/
Although these are Bosch MED17 ECUs and the XKR is Denso, we still have similar capabilities for the XK models. Just finished tuning this car for a US Dealership with a pulley and our tune. Techs took the car out and said it runs super-smooth, pulls like a freight train and doesn't stop, and wants to overpower the traction control!
Our software is available for the XKR via our V-Tech touch-screen programmers at $995, Supercharger overdrive pulleys for $195. The programmers will store up to 5 modified files, so you can choose a Tune, and a Tune + Pulley if you wish to upgrade at a later date. The Original file is also stored on the programmer and can be flashed back onto the ECU at any time.
Jaguar/Landrover 5.0 Denso ECU Tuning
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
We have a similar pulley upgrade & tune, doesn't make 600BHP
Our tool is not configured to flash the 4.2 however, so for the time being that would be bench flash only (send ECU to our office in British Columbia)
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Please post some detailed dyno results. Its the thing that keeps many of us from getting our toes wet.
Also what are you doing to address the carbon buildup problem. Apparently Jaguar backed off some of the performance in order to keep the intake clean and it has worked. The Germans have had huge problems.
Carbon build-up... tell me more about this? I'm not familiar with this. I doubt they backed off on performance for this since they are now running 550BHP F-Type R, 575 in the Project 7 and apparently 617ish in the SVR. Although I could be and frequently am wrong!!!
Our in-house tuner is a factory qualified Jaguar technician so I will ask him to chime in.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Namely its to do with fuel trim and timing. By being off a little you get the benefit.
Look we are just lay people looking for expertise.
Don't have detailed dyno results for the Denso Cars. I have some for the Bosch F-Types which are very similar apart from the PCM setups. We can share that information, just chasing up a dyno operator for the last 'after' sheet.
Jaguar has not solved the carbon build-up, the Germans have actually come up with a solution on newer models. The carbon is caused because of the direct injection. Jaguar and Land Rover have played with there software but still have issues along with the injectors blocking and forcing a misfire.
The Germans(VAG) have started fitting a fuel injector back into the intake manifold to spray fuel and allow the oil to wash away. The engine still runs on the direct injection though..but again have an addition injector to help solve the issue before it starts. Jaguar and Land Rover have not started this (probably patents by VAG). Jaguar/Land Rover are also using a 0W20 and 5W20 versus VAG using stuff thicker like 0W40..just the oil also could be why VAG has delt with this more and to a higher level.
Queen and Country (04-06-2016)
There's no need to be so unfriendly, we are not a fly-by night company. We have been around for 8 years, are official suppliers to Aston Martin Racing and deal directly with a number of Aston and Jag/LR dealers. If you would like to speak with a couple of the technicians who installed this pulley and tune on the Red car today, I'd be happy to give you their phone numbers in private
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
The fourth graph down is from a Jaguar XF 5.0 Supercharged which we had tested at an independent dyno. 75BHP with addition of sport cats, majority of the gains from pulley + tune.
VelocityAP 75BHP Power Pack for Jaguar XF 5.0SC and XF-R
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
So far I am extremely pleased with the support. Thank you.
Your professionalism is duly noted. Thank you.
I tried to purchase a tune from Jaguar experts and the data they sent me was a joke. Hopefully you understand my apprehension and you have put it to bed. As a return favor here is the graph your competitor sent me.
But I'd still like to do it. Really what I need is a car here in BC in our shop. we have a 2015 F-Type R coming in some time in the next month or so, and we'll be building both V8 & V6 Headers on that.
Perhaps we could take one of the V8 headers and send to you, and you could test-fit to check for interference etc. It will be quite similar, but I wonder if we could also adapt an F-Type design if we were supplied with your OEM downpipes to bolt up to an OEM manifold....
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart,
Try not to comment on competitor stuff so I won't, other than that it would be helpful to see both Axes! Actually, true story, Paramount Performance was my very first customer when we started the exhaust business back in the UK in 2007. Bought a 2005 AM Vanquish Exhaust I think. True story!
I still don't know what the scoop is with Paramount because they closed down for a while in administration, or so I was informed. I know the guy who was the ex-MD went to Viezu (ECU Tuning Company) and it appears that Paramount is now based there.
Seems like they are doing well, they always had a good following for Jag stuff.
Anyway, don't know about professionalism, we're a bunch of barely-grown up man-children, so my wife says
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Jaguar would have to have backed off the power. It cant be that they are only just discovering how to tune it in the Project 7. Question is for what reason did they back off. If it was just a matter of software, go on give us the SVR tune, we will pay $3k.
Stuart,
Thank you for posting here. I have been searching for a tune for many many years but have not been able to find one that guarantees results. I am very interested but would like to know what it would take to tune my 2008 XKR without having to to remove the ECU. What would it take for you to come up with one, I especially like the idea of having a tool like the one for the 5.0. Thank you in advance.
This is my Dyno - 2014 XKR.
Before an after Chiptuning and deleting the speed limit 250km/h
Bad first result, only 487 HP - reason was normal Super 98 Oktan, no German Super Plus 102 Oktan.
Now I use only Aral 102 Oktan and I think, the XKR has more power.
Queen and Country (04-07-2016)
Paul Busby was a small partner of Paramount performance together with Martin Lane (now working for quantum tuning) and myself. He left to move to Jamaica as he told us all but really went to start a company called viezu. He took access to the email system of paramount performance and the company failed soon after with me paying all creditors. He then stole viezu from his new partner and when he went to go public Linda Busby took legal action and placed an injunction on him to stop him from making public the in house workings of the company. The rest is history.
Paul took on paramount performance after it was closed and continues to run it as a business without the end users realising the background. he started VIP as he was unsure of how the injunction would pan out in court.
The following 3 users liked this post by stuarth:
