Vibration certain RPMs
Received 2,048 Likes
My 2010 XKR with about 190,000 miles on it has recently develoed a very light vibration as well. I just put new front tires on last week, so they were balanced, and I had the vibration before the new tires. It is ever so slight but knowing how smooth this car has always been, I do notice it. I'm guessing it;s something in the drivetrain not the tires.
steve_k_xk (10-22-2021)
Received 1,177 Likes
or worn tires? cupping of the tires? alignment? worn suspension part…
It was at my last alignment that I learned one of the bolts in the bushing of the strut was about to fail…. I went in for the alignment early that time…. the car didn’t feel right when making sharp left turns at speed and had an unexpected vibration in the car.
Are you able to determine where the vibration is coming from
That is - rear of vehicle could be diff
If its slighty behind you it could be a faulty tailshaft bearing or
if your feeling up near your feet as suggested by moses it very well could be that the torque convertor needs to be re-balanced.
F1wannaB
03-28-2015 07:41 AM
