VIC
If the module that generated the code does not reproduce that code after 3 cycles of the ignition typically the fault light will not return. The cluster lights are LEDs by the way. Resetting the car via the method mentioned above would be the next step if the light and code return. Also make certain the battery is either been tendered or new and these cars as well as many modern cars are sensitive to battery voltage drops. A good OBD scanner or dongle with an app is also recommended. And lastly anything software related to the car must be serviced via Jaguar specific diagnostic and service equipment.
My comment about lower cost still stands - if a mechanic just started swapping sensors to try and fix this sort of problem, I doubt you'd be leaving with a bill of only $350. Not unless you have an indy shop that has a load of spares to swap in & out, and pretty low labour costs.
My indy specialist has the same Jaguar diagnostic system as a dealer - they also have a subscription that supplies the latest software images. So, a proper Jaguar specialist should have the necessary tools; if they don't, they're not a Jaguar specialist - at least, not a specialist in modern Jaguars, because you can't really work on them without the official diagnostic system.
Problem is, with swap-out troubleshooting, you have to pay them to put the old one back, or pay for a replacement part you don't need. That's why having the full diagnostic system can really help, because it can give further info to locate the problem. Normal code readers only pick up the first 5 characters of the code - the Jag proprietary system picks up two extra characters that may give greater detail.
However, in your case, there isn't any further detail for that code - it's "P243100: Secondary air injection manifold absolute pressure sensor circuit range/performance". No sub-codes, unfortunately.
