want to know if my xkr is a portfolio
Old 09-20-2013, 03:03 PM
jagxk2008's Avatar
Default want to know if my xkr is a portfolio
xkr 2010. it has a heated steering wheel and the black alcantara textile inside, ac with seats and directional lights are serie. can you help? do you need a vin? to find out. i know my 08 last one was and had less options. well sorry i think there is no portfolio xkr but only xk.
Old 09-20-2013, 07:34 PM
richzak's Avatar
Received 1,233 Likes on 789 Posts
Run the VIN via Google...I am sure you will find out .
Old 09-20-2013, 08:01 PM
rscultho's Avatar
The 2010+ has all of the options the earlier years had that were marked with "Portfolio".
Also, the 2010+ MY's have a different door panel leather configuration and a few things the earlier year "portfolio" cars did not have. I used to have the list...will try and find it.
Old 09-20-2013, 08:06 PM
Bruce H.'s Avatar
Canadian equipment packages may be different, but I believe the 2008 XKR Portfolio was an option package, the 2009 XKR Portfolio was a separate trim level, and then it disappeared entirely as some of those features became standard along with the other 2010 XKR upgrades.
Old 09-20-2013, 11:22 PM
British packages continued the Portfolio designation for XKs even through 2010. I'm assuming you are in Spain? Would the options packages be the same as GB? You're right, XKR had no portfolio.
Old 09-21-2013, 05:12 AM
jagxk2008's Avatar
thanks a lot guys. its a french one from Le port marly jag
Old 09-21-2013, 07:00 AM
Stuart S's Avatar
Received 6,286 Likes on 3,450 Posts
My 2009 XKR Portfolio has door sills embossed with "Portfolio" instead of the standard "Jaguar" designation as well as a "Portfolio" badge on the rear. Other differences unique to the Portfolio include Shadow Gray paint, Selena wheels, gear selector knob, and milled aluminum vents on the front fenders.
If your car is a Portfolio model, I think it should say so somewhere.
ricwel
06-23-2023 05:14 PM
GGabriel
11-22-2018 03:53 AM
ziondio
10-01-2015 01:48 AM
ziondio
09-28-2015 11:24 AM
vacolorito
09-25-2015 09:29 AM
Quick Reply: want to know if my xkr is a portfolio
