Warning to Jaguar owners! If you don't want to die, change your vacuum tubes!!
Wow what a day to be alive! Angels must be watching over me!
The title is not an exaggeration!
Yes vacuum brittle plastic tubes in later 5.0 cars can literally kill you as I have found out today!
So I leave my house to play some volleyball today. I live just a few minutes away from the unramp onto the highway which I was planning on using. Before the unramp all the sudden when I try to brake there's nothing there, pedal is all the way down to the floor, car just keeps going as I try to brake "Wtf?" it's going through my mind, luckily I was probably going 10 mph and as I used pretty much all the strength I had in my leg was able to pull over. I turn around and slowly make it back to the house using all the strength in order to stop. I can't even imagine what the scenario would look like if I was coming from the highway with high speed. Examined the car at home and what do I find under the hood.?. Small plastic tube completely separated broke at the t conection.
WTF Jaguar ? At least with the old rubber tubes they would slowly deteriorate not completely fail like this. I had a lot of cars in my life and never had a near complete failure of the braking system as I did in my Jaguar!
Moral of the story if you want to live, replace your vacuum tubes on regular intervals ))
There is no emergency brake. Only an electronic parking brake. Only used for.... well, parking.
Trying to engage it while moving will do nothing except make the instrument cluster chime.
The only thing the owners manual says is to only engage the parking brake while moving, in an emergency but this is in the Chassis Technical Guide for the X350/X150/X351 and XF:
Electronic Parking Brake - Dynamic Apply
There are two dynamic apply modes: low speed dynamic
and high speed dynamic. The low speed dynamic mode
operates at speeds between 2 and 20 mph (3 – 32 km/h).
The high speed dynamic mode operates at speeds above
20 mph (32 km/h).
If the parking brake switch is pulled up to the apply posi-
tion and vehicle speed is within the low speed dynamic
range, the EPB module drives the actuator to apply full
parking brake force to the rear wheels.
tion and vehicle speed is within the high speed dynamic
range, the EPB module will apply braking force to the
rear wheels at a slower rate until full braking load is
reached or the switch is released.
The rate with which braking force is applied is controlled
by the EPB module, which monitors both current drawn
by the actuator and positional information from the actu-
ator Hall Effect sensor and compares this to information
held within its configuration software.
I don't see why you can't make a split vacuum tube out of copper tubing and never have to worry about these braking or replacing again. Any thoughts on this?
JDog
I did this on a Bentley Continental, notorious for cracked plastic vaccum lines that require engine or steering rack out to replace, depending on your year.
In this scenario, couldn't you just pull the EPB? Rear brakes only but it's better than nothing.
JDog
yea I would take copper, aluminum or rubber any day over crappy plastic..
Here is the part # C2D7775
I can't believe this little plastic tube is $130
So to replace all of these plastic vacuum tubes on the vehicle is probably going to be a thousand bucks. I wonder how much the aluminum or copper custom tube would cost..
Where on the 5.0 is the vacuum check valve for the booster line? If the leak is between the booster and the valve, you're screwed. If the leak is between the engine and valve, you should still have vacuum in the booster.
