Warning Light
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Anybody know what this light is suggesting? On a hard right turn when slowing down with braking, the center clock display area disappears and for an instant a red triangle with exclamation mark flashes on the immediately goes off. This has happened a couple of times and is really hard to catch because it happens so quickly. Current mileage is 75K
If it's too fast to see you need to read the codes with a code reader. A red triangle is a high level warning and per your owners manual, you should stop driving it until the issue is resolved. My "GUESS" is low coolant or brake fluid. Get a code reader. It will go a long way and pay for itself many times over. Something like the Autel AP200 which will read more than just engine codes. It will also read chassis and body codes. About $80
The following 2 users liked this post by GGG:
ExKayRick (04-08-2022),
steve_k_xk (04-08-2022)
