Washing underside of XK Coupe
I was kind of afraid to go through the car wash and get the under car wash done. However, I ran over a varmint and got some really bad road kill smell so I had to have it done. I had them do a double under wash and it did get rid of the smell with no problems. Now I get it done every few months. It also does a better job of getting rid of brake dust inside the rims if I'm too lazy to get down there and clean them.
britannia (12-21-2013)
britannia (12-22-2013)
Look at it this way when there is a major oil spill and they need to get the ducks cleaned they use Dawn liquid detergent. Also if you ask a good detailer the will most likely tell you they pressure clean the engine bay and the undercarriage. So take it from there and if you have a clean car with no oil leaks then the car wash undercarriage wash should keep it clean. As for me I usually move my 4 post lift (it has wheels) out on my driveway and use my pressure washer to do the undercarriage. It takes a day to do our 2 (was 3) cars and truck. Remember if you do it at the car wash the undercarriage spray is at the beginning as you drive in so go very slow.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
