Water from drain tubes??
Picked up my 2008 XK last week and I'm thrilled so far but I have my first newbie question...
Why when I'm only using heat and it's 35 F in PA am I seeing two little parallel puddles under the car at the back of the engine. Looks like condensation but not running A/C.
If it's near the middle rear of the car it is usually condensation leaking out of the exhaust pipes where they connect. This will happen for a while until you burn the water vapors off with a little spirited driving. If the puddle is under the transmission then it is the AC drain.
Take you HVAC system off the auto setting. Shut off A/C. Run the car and if you still have water dripping, it's likely condensation from the exhaust at the joints like Jagtoes and Hafren indicate. Happens to a lot of cars. If by turning off A/C, the water stops, then what Cee Jay said....
You leave it running in the garage and look under that car you can see it dripping from exhaust joints up at the mufflers.
larys192
12-21-2014 04:35 AM
