Water Pump Replacement
My water pump in growling on my '08 XKR, so time to replace it. Jag original pumps seem to be around $250, whereas Eurospare, Airtex, Beck/Arnley and other aftermarket ones are only around $50. Should I buy the Jag one or are there any particular OEM aftermarket ones that are good but cheaper? also, anything else I should replace while at that stage of tear down? thnx
PEP Boys has a good one that i'm using now. The gasket is just as important, I would avoid paper ones unless you buy a pump with an 'as-cast' mating surface. Check the 'waterpump replacement' sticky for more info.
If you remove the coolant manifold, it would be a good time to replace the thermostat. At that point you will need to replace 3 gaskets (2 for the manifold, 1 for the thermostat) that only Jaguar sells, but they are pretty cheap.
@64k miles, I replaced mine as a preventative maintenance and a "well, while i'm here..." kind of thing. It started leaking @76k miles from the paper gasket, and pump mating surface. That's when I replaced it with a metal gasket type and a pump with a machined surface. Haven't had an issue since.
I'm sure the OEM pump will last a while and they are relatively easy to swap out, but in my experience .... GAFF (gaskets always fail first). If you're doing a big maintenance job like i did, then replace it. If you just want to replace the pump/gasket, you can probably wait till 100,000 miles or more without an issue.
I thought I did a reply but it doesn't appear to be here - have the mods deleted it? All I mentioned was contact Berkshire Jags in England - they do the OEM Pumps for about $70 along with the header tank etc plus a load of advice - they have simply gone to the manufacturer direct. Very useful resource.
peterv8 (01-20-2021)
OUScooby
01-19-2021 11:07 AM
