water spots on the paint
South Carolina rain must have been contaminated/polluted or something. Under some lighting conditions, when looking closely at a certain angle I can see the water spots on the beautiful paint.
Tested the 50/50 water with white vinager method on a small area but no improvement.
Any ideas?
Any ideas?
The "water spots" have etched the clear coat. The Jag clear coat is relatively soft. I had the same issue on my roof last year. I used a light cutting compound (meguiars 205) and a DA polisher with an orange cutting pad. Took a few passes but I got it smoothed out. A more aggressive compound would have been faster but I wanted to be careful.
Queen and Country (06-27-2019)
I usually don't, but recently used the "squeegee" at the filling station on my windows. Later that day noticed streaming on my (black) paint from where water had run off from the glass. Thinking water might've been polluted by gasoline from someone - intentionally or otherwise. Hoping streaking can be finessed out by your method...
YouTube has a ton of videos on how to correct and detail paint. Spend some time there and on the internet learning about polishing and correcting before you try anything. Both of you have dark colors so if you are not confident, pay a pro. It's not that hard but better safe than sorry. Practice on something else before you hit the Jag.
shemp (06-27-2019)
Any ideas?
Any ideas?
Before using cutting compounds and polishers I would try a simple solution, wash then use a claybar with lubricant. If you haven't used a claybar before just google and there are a ton of detailer oriented tutorials. That could clear up the contaminants from your clearcoat.
riverman (06-28-2019)
Are you guys using a quality sealer? I've been using Meguiars Ultimate Fast Finish. It's easy to apply and take off and I find it resists dirt and road grime pretty well. The Jag lives in the garage and I dry it off when it gets wet by my Lincoln stays outside in the weather and is holding up pretty well with the Ultimate Fast Finish applied every 3-4 months. UFF is a coating though. It does not remove streaks and spots FYI.
I'm a fan of the Meguiars line. It's easy to use, readily available and reasonably priced but there are TONS of quality cleaners, sealers and waxes on the market now.
mosesbotbol (12-17-2022)
Tervuran, I'm on Long Island, but I suspect the wash water was contaminated - first time ever this happened.
I've always been hesitant to put anything other than cleaner / water / wax on cars, but will go the clay route if simpler methods fail.
Thanks to all for suggestions / remedies..!!
mosesbotbol (07-01-2019)
In the end the Nano Mitt costs less IMO. Clay bar fall on dirty floor and that's all she wrote. Nano matt last much longer. I have the medium and fine grad mitt and would recommend the fine if someone is to buy only one. It's much quicker the mitt than clay bar. I can do an XK with the mitt in like 15-20 minutes max. Fine polishing is recommended after the mitt; before a sealer or whatever you plan on applying.
shemp (07-01-2019)
As far as clay bar or nano mitt removing water spots, I agree, try it first, it does not hurt, but if a vinegar solution did not work, I doubt the clay will. The clay will pull off surface contaminants, which the vinegar solution should have done. But yea, give it a try!
Like Moses said, the clay will lightly mar the clear as it is an abrasive. You will see where you clay it on dark paint for sure. A fine polish will fix it up.
Agree. The Nano Mitt works great for the average Joe like me. There are still sticklers that swear on clay bar only though.
On the fence whether to use CarPro IronX before the mitt. I have like a gallon of it, but it makes the car smell for a few days. My wife's Volvo has iron spots in the paint, so for sure using on it her car.
More lube is needed with the Nano mitt. If the mitt drags, the rubber left behind is a pain to remove. I'll never use clay again.
I have yet to use an iron remover however.
I leave the car wet after the wash with dish washing soap to help remove the old wax and sealer. I just spray additional lube onto the wet paint with mitt and then wash the whole car again (minus the wheels) which is super quick since it's already clean.
shemp (07-01-2019)
