I have a 2010 XKR and currently keep it parked outside until I have a new (wider) garage door fitted - I can then 'fit' it in the garage. Until then, I cover the car with a (supposedly) 100% waterproof cover. The cover is not waterproof and consequently leaves water marks on the paint work which takes a lot of 'washing' out with a sponge and soppy water. Do any of you out there recommend a 100% waterproof cover? I spent £250 on this cover and it doesn't work. Would appreciate your comments...
I don't think you want anything waterproof since it will also trap any moisture under the cover. I use a covercraft Noah cover which has seen over a year of service including one full Northeast winter. It keeps off the major stuff like leaves and bird poop, but it does let water through. I brush it with a California dust brush before putting the cover on to prevent any grit from scratching the car while covered.You also need to wash the cover a few times a year so any trapped dirt doesn't seep through.In my personal opinion, a garage is the only way to keep the car pristine.
One more thing about totally waterproof covers.... any water underneath the car, and ESPECIALLY if you park it on dirt or gravel... all the moisture from beneath the car will migrate UP and completely coat every accessible area, including the engine bay. This will make a total MESS of any metallic pieces/parts.
If you can, return that very expensive cover and get your money back. If your new garage door will be fitted soon, then I'd just leave the car outside without a cover for the time being. But I'd be sure to give it a good coat of wax to protect it from the elements.
A completely waterproof cover will ruin your paint. That's why every reputable manufacturer of car covers uses breathable fabrics. Some breathable covers are more water repellent than others, and repellency varies with cost - the more you pay, the more repellent the cover. But they all allow water to penetrate.
If it is only temporary them why just polish with a good quality polish and sealant.
I use Autoglym Resin Polish and Autoglym Extra Gloss.
You will get a plethora of suggestions but any good quality polish will do.
I use a half cover on mine and a full cover the TVR. Mostly to keep the local cats off the roof as it's a convertible but with the added bonus of keeping roof clean and dry.
Hamilton Classics is where I got mine from. You need a four ply cover as not only is it breathable but it has a soft inner layer to prevent scratching of paintwork.
All of these covers have a shortish life span as the UV and rain do affect the fabric if used daily. 4-5 years is what I expect them to last. A Stormforce one I had lasted 2 years before it fell apart
Thank you all for your many, and great, responses. I wasn't aware of the potential issues of using a fully waterproof cover, so ill forget that approach. I really like the storage shelter idea, but I guess I should wait until I get a larger garage door fitted so that can then ft the car in the garage. In the meantime, I'll give it a good clean and polish and continue enjoying my pride and joy. Thanks again for all your great advice
