What is this?
What is this?
Hi
first time Jaguar owner and trying to learn as much as possible about the vehicle. Have a 4,2 n/a 2009 model year and try to figure out what this is as it has a small oil leak. Do I only need a seal or the hole part? Its a kind of a sensor, isn`t it?
This from the front of the left banks
Received 2,675 Likes
Ter11 (01-10-2021)
Make sure the seal is fully seated into the opening on the cam cover then reconnect the electrical connector.
Seal replacement
It's a two minute fix, but take your time.
Just remove the connector - Squeeze and slide towards rear. It might seem tricky but try not to force and break it!
Ease out the old seal with a flat blade and slide all the way off the vvt actuator body.
Clean around the actuator body and the hole then slide on the new seal and push it all the way down all around until it's totally flush.
Refit the connector.
Here's a source for the replacement seal ...
2007 JAGUAR XK 4.2L V8 Variable Valve Timing (VVT) Solenoid Gasket | RockAuto
You have 2 posts in this thread that were automatically locked for moderation.
I couldn't see any problem with the text and it took a while to work out what was happening. It's the use of 2 emoticons together that causes the algorithm to block the post.
I've umlocked them now.
rf69
07-06-2018 09:36 AM
