What did you do to your X150 today?
Old 03-02-2023, 09:01 PM
I read the stock tune off my ECU and sent it off to VelocityAP for "Stage 1" spicy sauce No pulleys or other hardware needed for this, should result in 565hp/517tq at the flywheel.
The following 2 users liked this post by BagelConsultant:
resident_fng (03-03-2023), Wm. Lyon (03-03-2023)
  #1982
Old 03-03-2023, 06:31 AM
steve_k_xk's Avatar
Received 1,550 Likes on 895 Posts
Originally Posted by Wm. Lyon
Those look great in black!👍 But, kinda trying to convince myself into a Mina back box!😂🤣
By the way, do you still have your original back box in place? Also, did you notice much difference (in anything) after installing your X-pipe?
Thanks !
Yep that's the stock rear box I ended up dropping it and sprayed the entire unit , with the x-pipe the tone changes to a higher pitched note as opposed to that beefy V8 sound...think of it sounding more like a flat planned crank sound now.
Mina boxs are pricey!
  #1983
Old 03-03-2023, 12:09 PM
Wm. Lyon's Avatar
Thanks !
Thanks for the info. I actually had a resonator removed/X-pipe installed yesterday. Even with the stock muffler sounds great....for now!😂🤣
Mina is a bit pricey but, their HQ is only about 60 miles from home so, going to pick it up would be a savings of shipping a European model. Would likely still have it shipped ($45. US) as a 60 mile drive across Los Angeles could take all day....maybe 2 days round trip!😁
steve_k_xk (03-05-2023)
  #1984
Old 03-03-2023, 12:19 PM
Joe7Bros's Avatar
Can I ask what it cost to have your mid pipe modified? Is the x-pipe section welded in or slip-on? I've been pondering doing the same thing, I already have an XKR rear box on my XK
  #1985
Old 03-03-2023, 12:39 PM
Wm. Lyon's Avatar
I ordered the X-pipe from Jeg's mail order for about $100. The muffler shop I went to charged $200 to install. Even with the stock XK back box, I like the new sound much better. A little more rumble at idle and raises pitch as rpm increases.
Edit: My X-pipe was welded in. Also, absolutely no drone!🙂
The following 2 users liked this post by Wm. Lyon:
Joe7Bros (03-05-2023), steve_k_xk (03-05-2023)
  #1986
Old 03-05-2023, 07:29 AM
steve_k_xk's Avatar
Had custom made for mine however can use original mid pipe and have x-pipe welded in
The following 2 users liked this post by steve_k_xk:
Joe7Bros (03-05-2023), Wm. Lyon (03-12-2023)
  #1987
Old 03-05-2023, 09:32 AM
Joe7Bros's Avatar
Checked out the Jeg's offering; have to check the center to center measurement on the original pipes.
  #1988
Old 03-05-2023, 09:34 AM
Joe7Bros's Avatar
Looking to find a used mid-pipe to cut up and add the x-pipe
  #1989
Old 03-05-2023, 09:47 AM
Wm. Lyon's Avatar
Center to center on X-pipe is definitely bigger. My muffler shop made it fit and it looks & sounds great! Guess they have a big hammer!
steve_k_xk (03-07-2023)
  #1990
Old 03-11-2023, 06:45 PM
mhminnich's Avatar
Default Finished 'blinging' my XKR
Replaced the window surround trim on the R today with the polished variety. Now everything matches the chrome Sentas. That also means i have a complete set of anodized R trim to offer. Pm me if interested.
The following 5 users liked this post by mhminnich:
BlkC4t_XK14 (03-11-2023), McJag222 (03-11-2023), Sean W (03-11-2023), V7Sport (03-12-2023), Wm. Lyon (03-11-2023)
  #1991
Old 03-11-2023, 07:12 PM
Wm. Lyon's Avatar
Looks GREAT!!👍👊
mhminnich (03-11-2023)
  #1992
Old 03-12-2023, 06:16 AM
Brachacz's Avatar
Had 1-step paint correction and ceramic coating applied. Pretty sure it would glow in the dark with the lights turned off!
The following 5 users liked this post by Brachacz:
guy (03-12-2023), McJag222 (03-12-2023), ralphwg (03-12-2023), Sean W (03-12-2023), V7Sport (03-12-2023)
  #1993
Old 03-12-2023, 06:51 AM
guy's Avatar
guy
guy is offline
Received 1,104 Likes on 777 Posts
Nothing “sexy” to report. (like that beautiful car @Brachacz ) Gave her a brake service. Cleaned up the calipers (including all pins, etc), used brake klean and a brush, then brembo brake grease liberally and deglazed the rear pads.
While in there, started contemplating the need to drop the subframes and paint them, pretty. The feeling quickly subsided when a buddy called to suggest we meet for a quick pint at the pub.
Also contemplated painting the outer caliper bracket… But I don’t want them looking like everyone else. So I left them alone.
Pads are half worn…. I left them alone for now. (Why do the inner pads wear faster than the outers?)
And the braking feels “new” again.
Car seems solid enough but there is a slight spongy feel as when hitting irregularities in the road. I think new dampers are on the horizon. I did try lowering springs once and did like the look. But the feel was wrong when driving the winding road in a spirited manner… yes, probably just the dampeners…
The following 2 users liked this post by guy:
  #1994
Old 03-12-2023, 07:00 AM
guy's Avatar
guy
guy is offline
Pretty, @mhminnich !
Surprised to not see these though…
Sean W (03-12-2023)
  #1995
Old 03-12-2023, 09:57 AM
Wm. Lyon's Avatar
Not a car classier looking than a clean balck car!! Love the reflection of the pavers on the door in the last picture! Looks GREAT!👌👍👊
Brachacz (03-14-2023)
  #1996
Old 03-12-2023, 06:19 PM
mhminnich's Avatar
That does look nice. My vents are pretty ratty, so maybe...
  #1997
Old 03-14-2023, 10:41 AM
MonkeyJosh('09)'s Avatar
Default DRL leds installed
I'm finally coming around to doing small cosmetic items while I prepare to hit some essentials (upper, lower control arms, tie rods, etc.) and decided to add DRL led strips to the headlights. I found the headlight wiring diagram and spliced a few wires in order to give them an OEM function, and it came out exactly as I wanted. I also saw a suggestion on one of the forums to replace the amber side markers with white leds and I couldn't be more pleased! I'm curious on y'all's opinion! I also have some DRL angel-eye fog lights coming in soon
before: I'm sure you all know the classic "egg yolk" look
I made some videos on how I installed it and am considering making it a YouTube video, but I'm still debating...
File Type: mov
  #1998
Old 03-14-2023, 10:50 AM
Cee Jay's Avatar
Received 5,363 Likes on 3,175 Posts
Cool and all, but for a hint, next time LINK to a video instead of attaching it. Now everyone will have to download it before watching. Even YouTube works for linking, or TT, or myriad other online places.
The following 2 users liked this post by Cee Jay:
MonkeyJosh('09) (03-14-2023), Wm. Lyon (03-31-2023)
  #1999
Old 03-31-2023, 01:00 PM
Wm. Lyon's Avatar
YouTube video on the install would be great!
  #2000
Old 04-01-2023, 04:28 PM
gmuirnz's Avatar
Nothing! 'XKPURR' is sitting in my garage at home in NZ while I am in Melbourne, Australia at the F1 grand Prix
The following 2 users liked this post by gmuirnz:
bgpenguin21 (07-27-2023), V7Sport (04-02-2023)
Quick Reply: What did you do to your X150 today?
