What did you do to your X150 today?
Old 07-24-2023, 09:29 AM
Stuart S's Avatar
Received 6,334 Likes on 3,471 Posts
Originally Posted by George Abitbol
This weekend, I fixed my glovebox...again. ...
The sh*t plastic arm (seriously, how could they come up with such a crappy design in a car like this, instead of using something proper like a hydraulic cylinder?? )
George,
I know you're in Luxembourg, but don't know if Amazon is available there. If not, and you want to try this, PM me if you can't find this item in Europe. It's made in China.
I used these small, inexpensive ($17.99/pair) gas spring dampers to fix my antique dropdown desk, and thought they might work to fix your broken glovebox lid. If you're an Amazon Prime member, there's no risk because returns are free. I haven't done any measurements. Only one would be required, as the glovebox lid isn't heavy. It'll keep the lid level at a 90° angle when fully open.
http://Qrity 2 PCS Flap Stay Damper ...a.co/d/5SNYTTC
Stuart
ralphwg (07-29-2023)
  #2102
Old 07-24-2023, 09:57 AM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
Running down the maintenance list ..tonight it was the left hand engine mount and left hand Valve cover .
The following 2 users liked this post by steve_k_xk:
bgpenguin21 (07-24-2023), McJag222 (07-24-2023)
  #2103
Old 07-24-2023, 02:42 PM
bgpenguin21's Avatar
Today I had my annual post-cancer-thyroidectomy scans. Had been on a low-iodine diet for 10 days, so I decided that a run to the McDonald's drive-thru for some salty burgers & fries was next on the schedule.
Hopped in the Gray Ghost. Put the top down and enjoyed some fresh air on the way there. Got some smiles and thumbs-up gestures from a sweet octogenarian couple walking down the street during my short excursion. Was able to legally blow past a Camry driving 10mph below the speed limit on a 2-lane road in about 1.5 seconds.
I also managed to keep from dropping any fries in between the seats.
All in all, I'd have to call this a pretty good day.
The following 9 users liked this post by bgpenguin21:
CA Jag (09-01-2023), CurtJ (07-24-2023), earny (07-25-2023), kj07xk (07-24-2023), McJag222 (07-24-2023), mhminnich (07-24-2023), panthera999 (07-25-2023), ralphwg (07-29-2023), V7Sport (07-26-2023) and 4 others liked this post. (Show less...)
  #2104
Old 07-25-2023, 11:03 AM
panthera999's Avatar
Steve,
What were the indications you needed a new mount? Noise on speedbumps? On gunning the engine? something else?
How many miles? Did you use a Jag part, or aftermarket?
The following 2 users liked this post by panthera999:
bgpenguin21 (07-26-2023), SDCR_XK (07-25-2023)
  #2105
Old 07-25-2023, 04:19 PM
steve_k_xk's Avatar
I normally do a load test on the engine to see there is movement (engine in gear one foot firmly pressed on brake the other giving some quick revs to the throttle) this time it wasnt required I could literally hear the engine moving around under WOT
I used after market part however xj, f type , xf , s-type all run same mounts
The following 3 users liked this post by steve_k_xk:
McJag222 (07-25-2023), Panthro (09-11-2023), Sean W (07-25-2023)
  #2106
Old 07-25-2023, 04:38 PM
Thanks -- how many miles on the car?
BTW, this is one case where it's nice to have the hood open forward -- you can gun the engine and see it move.
  #2107
Old 07-25-2023, 04:51 PM
steve_k_xk's Avatar
Wow Better then I thought
May 2018 - 79k (l/h eng mount)
July 2023 - 146k (l/h eng mount)
Lasted 5yrs and 67k km
  #2108
Old 07-25-2023, 05:09 PM
Thanks. I'm at 86K and mine are original.
  #2109
Old 07-25-2023, 05:26 PM
steve_k_xk's Avatar
Mines not quite a R nor a 4.2 lol I'm kind of in the middle I've got a 4.4 that redlines at 7100rpm so it might be those revs that are doing the damage ))) and obviously it all depends on how these things are driven
  #2110
Old 07-27-2023, 02:48 PM
J.J.'s Avatar
Checked tranny fluid level, was a bit low. Added 700ml, all good now.
Even on a lift, it was... fiddly.
  #2111
Old 07-28-2023, 11:28 AM
ptaylor2000's Avatar
At idle the engine had a deep rattle rumble from the front end. There was no overheating detected or warning lights displayed.
The mechanic put in a new water pump, flushed the cooling system, and refilled it with coolant.
Although the car only has 48, 100 miles on the odometer the pump's bearings were shot and the gaskets were weeping.
No rumble noises from the front of the engine now. Hopefully, this pump will survive at least 48,00 miles also.
  #2112
Old 07-28-2023, 09:14 PM
mhminnich's Avatar
After many delays, I finally finished up my valley hoses and 10% pulley upgrade. I seriously don't want to do those hoses a third time!
McJag222 (07-28-2023)
  #2113
Old 07-28-2023, 11:16 PM
Cee Jay's Avatar
Received 5,441 Likes on 3,211 Posts
Sorta like this???
The following 2 users liked this post by Cee Jay:
McJag222 (07-29-2023), Panthro (09-11-2023)
  #2114
Old 07-29-2023, 05:01 AM
mhminnich's Avatar
Sorta like, "I'm too old and too tired to be doing that again."
The following 6 users liked this post by mhminnich:
bgpenguin21 (07-30-2023), McJag222 (07-29-2023), Panthro (09-11-2023), Sean W (07-29-2023), steve_k_xk (07-29-2023), V7Sport (07-29-2023) and 1 others liked this post. (Show less...)
  #2115
Old 07-29-2023, 10:38 AM
McJag222's Avatar
Originally Posted by Cee Jay
Sorta like this???
Is that you son's car Cee Jay?
  #2116
Old 07-29-2023, 11:23 AM
Cee Jay's Avatar
Yes it is, you can tell because all the Seattle corrosion and such. Mine is nice and shiny.
I figured I'd do whatever I can since it's already this far apart, so the injectors are in an ultrasonic and while the plugs aren't bad shape-wise, they are still a bit dusty so the wire wheel for those.
Someone told me the coils are probably good so I'll just ohm those out and see if anything looks out of place.
THEN I get to put it together after I DIDN'T take it apart, so I'll be kind of clueless as to what the heck I'm doing. Plus new gaskets. WHERE do I find some? The lower intakes are easy, but how many others are there that I don't know about? SNG doesn't have any, and neither does the 'regular' suppliers I use.
Fun Stuff!
  #2117
Old 07-29-2023, 11:40 AM
McJag222's Avatar
Fun Stuff!
Right on, looks like you are making good progress. When I had my valley hoses done all the gaskets were available for the local Jag dealer. I don't think they had them in stock locally. Probably came from Toronto.
After looking at various threads I came up with a parts list for the dealership parts dept as what they quoted seems to be missing a few.
Remove S/C Outlet Pipe
S/C Outlet Gasket 1 NCC7735BA
S/C Outlet seal 2 AJ86925
Filler Sealing Washer 1 AJ89646
Remove Throttle Body
Gasket 1 AJ83445
Remove EGR Valve
Gasket, pipe1 1 AJ89071
Gasket, pipe2 1 AJ87246
Remove Coolant Mainfold
O-ring (housing) 1 NCA2269CA
O-ring (thermostat) 1 AJ83525
O-ring (housing) 2 C2C11477
Remove S/C Air Chargers (2)
Intake Gasket upper 2 AJ88047
Intake Gasket lower 2 AJ89062
Remove Water Pump
Gasket 1 AJ88922
The following 2 users liked this post by McJag222:
bgpenguin21 (07-30-2023), Cee Jay (07-29-2023)
  #2118
Old 07-29-2023, 03:43 PM
Cee Jay's Avatar
Gasket 1 AJ83445
Remove EGR Valve
Remove Water Pump
Gasket 1 AJ88922
I shall print your list and take it somewhere, or email it to the 'local' Jag guy, 40 miles away.
  #2119
Old 07-31-2023, 08:07 AM
earny's Avatar
When Leapers go wlld !!
Was planning on washing the car today ...not likely looks like I need permission first lol
Sorry Steve, related to this picture: do you have a wheel from a late XJ model on the rear? what size, 9x19 or 10x19? Do you happen to have more photos with the xj-rims available?
I have the chance to buy a set of those rims for very little money, so I´m thinking of buying them as a spare set. I like the look. Thx in advance!
  #2120
Old 07-31-2023, 08:38 AM
steve_k_xk's Avatar
They are off f-type having said that the offset is perfect for the 4.2 however for a 5l the rear offset is way off ....in regards to XJ wheels you are looking at as far as my memory serves me xj wheels arent staggered
earny (07-31-2023)
Quick Reply: What did you do to your X150 today?
