What did you do to your X150 today?
Old 09-11-2018, 09:05 AM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
Originally Posted by kj07xk
Yes, do tell. What’s the problem?
I see that you’ve got both XK (black) and XKR (green) shocks, and maybe (could be photo angle) the shaft out of the green shock appears a tad shorter. But I had that too, when I replaced my 2007 XK front shocks, with those intended for a 2010-2011 XK (by the part numbers anyway).
Had to squeeze the springs a bit further to get the nut on, but got it done. Just think the shaft on the old shocks was loosy-goosy, so it stuck out farther.
I measured the xkr vs xk shock and the shaft is 3mm longer on the xk
  #362
Old 09-11-2018, 12:22 PM
kj07xk's Avatar
Received 2,012 Likes on 1,345 Posts
Well, I wouldn't be surprised if the replacement you get is the same size as the xkr shock you already have.
Did you compare the 2 xkr shocks you were going to install, to see how they compared, side by side?
Like I said before, the new xk shocks I put in were shorter than the old xk shocks I took out, even though the one really bad shock I took out had lost its damping fluid all over my garage floor (a good sign the shock had gone bad ).
I had a heck of a time compressing those xk springs, and also had to use 4 compressors (rented the first pair, couldn't get it compressed enough, so had to go rent a second pair to finish the job, placing them at 90 deg from the ones already on the spring).
In your picture of the 3 springs, are they, xk, xkr, and eibach, from left to right?
  #363
Old 09-11-2018, 12:27 PM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
3mm???? That's like less than 1/8th of an inch... does it make a difference?
  #364
Old 09-11-2018, 03:28 PM
steve_k_xk's Avatar
When trying to compress a firm spring every mm of thread makes the difference
Cee Jay (09-11-2018)
  #365
Old 09-11-2018, 07:40 PM
Received 4,458 Likes on 2,427 Posts
Between Steve and myself we have four sets of springs and three different sets of shocks
Springs; XK, XKR, XKR-S and Eibach lowered
Shocks; XK, XKR and XKR-S
That pic (left to right) is XKR front spring, XKR rear spring, Eibach front spring, I believe
Very confusing to identify so it was lucky I took some photo's during the work on my car, there are no part numbers on the springs only coloured paint stripes.
Even more confusing is that the XKR-S springs are made by Eibach and are a totally different design to the aftermarket Eibach lowered springs, the XKR-S springs have part numbers on them, the XK & XKR ones don't.
My old XKR shocks went into Steve's XK to replace a faulty XK one (CATS fault) but one of them also failed after a while, which was the reason for new XKR shocks. But one of the brand new ones is faulty as well!!!!!
Plug one of the old XKR shocks in and the CATS fault goes away, plug in the new one it comes back...
  #366
Old 09-11-2018, 11:42 PM
kj07xk's Avatar
Is it possible the 'new' XKR shock is 'too new'?
Didn't the CATS system change at some point, from just 2 values (i.e. hard/soft), to a continuously variable value?
Maybe the new shocks don't 'play nice' with the old system?
  #367
Old 09-12-2018, 12:12 AM
4.2 are the on/off, 5.0 are the continuously variable.
He got two new shocks, one is fine, one is faulty.
It sucks, but it can happen.
  #368
Old 09-12-2018, 05:09 PM
Cee Jay's Avatar
I CUSTOMIZED MY WHEELS!!!!
Well, ONE of them anyway.
I pulled out of a Chevron and juuuuussstttt kissed a small curb that I didn't see....
  #369
Old 09-12-2018, 05:30 PM
Stuart S's Avatar
Received 6,320 Likes on 3,465 Posts
I suspect that everyone on this Forum has already been there, done that. Take comfort knowing that you are not alone. It's an "AW $H/T!" moment.
  #370
Old 09-12-2018, 06:02 PM
Cee Jay's Avatar
Yeah, an EXPENSIVE "aw, ****". I pulled over after about a mile to make sure it didn't get bent. Could have been worse.
  #371
Old 09-12-2018, 10:05 PM
peterv8's Avatar
Been there, done it!:-(
  #372
Old 09-13-2018, 07:47 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Well maybe not all of us have. Maybe scraped under the nose but you can't see that.
  #373
Old 09-13-2018, 10:01 AM
Stuart S's Avatar
Unless you're in an area with no curbs, it's inevitable given enough time. No one ever intends to curb a wheel, but the low-profile tires on our X150s make our wheels extremely vulnerable to damage. That never happened back in the day when the wide whitewalls took the hit and were easily cleaned up with a Brillo pad. Ain't progress great?
  #374
Old 09-13-2018, 03:23 PM
jagtoes's Avatar
Not a lot of curbs in the villages up here and none in the malls. I don't usually park in any of the local city streets as I am usually driving through them on our cruises. But I use the family car while in the cities and so far never curbed a wheel yet but the older I get brings in more of a possibility. I do seem to remember my OEM Dunlops had a curb guard where the rubber near the bead stuck out further then the rim.
  #375
Old 09-13-2018, 04:03 PM
shemp's Avatar
That's why I installed a set of these babies
Wm. Lyon (12-20-2022)
  #376
Old 09-13-2018, 04:10 PM
Sean W's Avatar
Received 4,256 Likes on 2,379 Posts
You can't have those unless you cruise to this
  #377
Old 09-13-2018, 04:15 PM
shemp's Avatar
Who says I don't???
Sean W (09-13-2018)
  #378
Old 09-14-2018, 08:01 AM
S-Typer's Avatar
Got the car all prepped for auto flex spray coating. This will black out the chrome similar to the Black Pack.
It’s a very glossy finish once applied (much glossier than plasti dip). It’s also completely removable.
I also sent the factory Orona wheels to powder coating (went with a very bright / light silver).
I’ll send pics of the results when I finish the application of Auto Flex.
I went a little crazy with the prep.. the application doesn’t have much overspray.
Joe
  #379
Old 09-14-2018, 08:08 AM
jagtoes's Avatar
My father had them on his 49 DeSoto.
  #380
Old 09-14-2018, 08:36 AM
shemp's Avatar
Joe
Can never be too careful!
Quick Reply: What did you do to your X150 today?
