What did you do to your X150 today?
Old 06-25-2020, 09:28 AM
Malawi's Avatar
Originally Posted by De5in
It's a 5.0l XK. I will be getting the tune from AlexJag. I will write it up exhaustingly and ad naseum I assure you.
interested to hear your thoughts
  #1282
Old 06-25-2020, 09:56 AM
Malawi's Avatar
Default changing lights to LED
headlights: changed the side marker, side lamp and cornering lamp to LED. waiting for 6000K new halogen bulbs for main light. I thought of going LED but too much work dealing with the balast etc. New HID bulbs are much better than 10 years ago.
Added a brake and turn signal LED to rear diffuser. looks superfly.
changed rear turn signal lights to LED. no resistor needed but it took a while to find good LEDs that would fit without hyperflash and bulb error.
left signal is LED so u can compare
replaced 3 bulbs to LED. got rid of the orange side marker bulb
diffuser LED
strobe brake LED light on right
now working on rear brake/running to install strobe LEDs. when u hit the brakes, the lights flashes 3 times then go solid. having bulb error issues with this light (P21/5W). installed resistors but problem not going away.
gkubrak (07-09-2020)
  #1283
Old 06-25-2020, 10:02 AM
Malawi's Avatar
Default Trying to fix rear spoiler LED brake light for cheap
work in progress. took the light apart. waiting for LED replacement light delivery
  #1284
Old 06-25-2020, 10:23 AM
Malawi's Avatar
Default installed new front LED fog lights
My prior LED burnt out after 3 years
full beam
daylight running
The following 2 users liked this post by Malawi:
kj07xk (06-25-2020), V7Sport (06-25-2020)
  #1285
Old 06-25-2020, 02:13 PM
kj07xk's Avatar
Received 1,974 Likes on 1,325 Posts
Originally Posted by Malawi
daylight running
What did you wire the DRL to?
  #1286
Old 06-26-2020, 12:46 AM
Malawi's Avatar
used a fuse tap.
kj07xk (06-26-2020)
  #1287
Old 06-28-2020, 11:24 PM
DannyJ's Avatar
full beam
daylight running
Do you have a link to the DRL enabled fog lights?
  #1288
Old 06-29-2020, 08:41 AM
steve_k_xk's Avatar
Received 1,548 Likes on 895 Posts
De-clouded my lens , repaired the two broken wires for the headlight solenoid and re insulated well over a dozen wires.
The following 4 users liked this post by steve_k_xk:
George05 (07-09-2020), kj07xk (06-29-2020), Marco75 (07-07-2020), Sean W (06-29-2020)
  #1289
Old 06-29-2020, 09:24 AM
Sean W's Avatar
Received 4,219 Likes on 2,367 Posts
Steve, what was the re-insulation process? Are we talking shrink wrap over the repaired wires, plastidip, electrical tape or did you do something else?
  #1290
Old 06-29-2020, 05:34 PM
steve_k_xk's Avatar
I had no shrink wrap available as it was too late to get some , so electrical tape it was .
My soul intentions was to simply de cloud my headlight lenses as vision was extremely poor , I had no idea that when I opened it up the wiring would be in such poor condition.
The following 2 users liked this post by steve_k_xk:
Sean W (06-29-2020), V7Sport (06-30-2020)
  #1291
Old 07-02-2020, 06:49 AM
Marco75's Avatar
Finally found a set of Takoba wheels for my Portfolio... had them refinished and installed.
The following 6 users liked this post by Marco75:
arenaej (07-02-2020), barnsie (07-02-2020), gkubrak (07-09-2020), ralphwg (07-04-2020), TexasTraveler (07-07-2020), V7Sport (07-02-2020) and 1 others liked this post. (Show less...)
  #1292
Old 07-03-2020, 03:56 AM
Default Fixing the Glovebox Damper
Hi!
Today I fixed my glovebox Damper.
Worktime just 1 hour.
Now the Glovebox opens smooth....
Screw to remove
Another two in the Box
Screw above the Power Socket
Another below the Box
Glovebox
Fixed it with a cable tie
The following 10 users liked this post by Laird Ravenscraig:
barnsie (07-03-2020), George05 (07-03-2020), gkubrak (07-09-2020), kj07xk (07-03-2020), Marco75 (07-03-2020), peterv8 (07-03-2020), ralphwg (07-04-2020), tberg (07-03-2020), TexasTraveler (07-07-2020), V7Sport (07-03-2020) and 5 others liked this post. (Show less...)
  #1293
Old 07-03-2020, 06:16 AM
barnsie's Avatar
Great pics! Thanks for sharing.
Laird Ravenscraig (07-03-2020)
  #1294
Old 07-03-2020, 06:22 AM
kj07xk's Avatar
Easy alternative to drilling a small hole and using a small bolt or cotter pin. Nice.
  #1295
Old 07-04-2020, 04:10 PM
JackJohn's Avatar
  #1296
Old 07-04-2020, 06:14 PM
Upper control arms replaced? any reason for that?
  #1297
Old 07-06-2020, 07:01 PM
JackJohn's Avatar
This weekend was a good one for the Jag. First, the battery was replaced, would not start on Thursday, put it on a 10a charger overnight, still wouldn't start on Friday. Purchased new battery and replaced it. Old battery was dated 10/2014 so it was time. Then over Saturday/Sunday we replaced the rotors with drilled and grooved ones from Stoptech and all new pads from Stoptech. Painted the rotors and put on new decals.
The following 3 users liked this post by JackJohn:
gkubrak (07-09-2020), TexasTraveler (07-07-2020), V7Sport (07-10-2020)
  #1298
Old 07-09-2020, 05:20 PM
vintageyz's Avatar
These are shots of my wheel change. I purchased the 20" Sentas damaged. A large crack in one and scuffs on all. Turned out there was more damage as the work went on. The repairs turned out great and the powder coat completed. I also did a ceramic coating on the all the wheels exterior and interiro. Now looking at a refurb of the wheel bolts and detailing on the wheel/tire combo.
The following 3 users liked this post by vintageyz:
gkubrak (07-09-2020), Sean W (07-09-2020), V7Sport (07-10-2020)
  #1299
Old 07-12-2020, 12:58 PM
peterv8's Avatar
Finally got the time for a polish! :-)
Used Sonax rubbing compound with green pad on my polisher, then Sonax polish with blue pad and last Sonax Hardwax with black pad! Happy with the result! :-)
The following 5 users liked this post by peterv8:
barnsie (07-12-2020), kj07xk (07-12-2020), Sean W (07-12-2020), shemp (07-12-2020), steve_k_xk (07-12-2020)
  #1300
Old 07-12-2020, 04:37 PM
V7Sport's Avatar
Looks awesome😎
The following 2 users liked this post by V7Sport:
peterv8 (07-13-2020), vintageyz (07-12-2020)
Quick Reply: What did you do to your X150 today?
