What did you do to your X150 today?
#1481
Winter tyres and summer tyres have virtually the same tread depth (7-8 mm) but a different pattern. However, increasing pressures on a winter tyre has the same effect as increasing pressures on a summer tyre. The guidance in the above post is misleading as it suggests that winter tyres simply need more pressure. Most people will assume that the starting point is the recommended pressure in the firstpalce. The downside of overinflation is that there is less tyre on the road and grip is lost which under unfortunate conditions could prove to be a serious mistake. We should be responsible with our suggestion or at least clarify their consequences.
#1482
yes, i'm curious about this as well, which is why i replied. he must have some idea of what the specific need is.
#1483
barnsie (11-30-2020)
#1484
Wow had no idea that my overinflation was going to cause such debate.
Let me explain, both alloys and tyres were indoors in the warm 10 mins prior to fitting. I have just check them in the cold (minus 2 C currently) and they are now sitting at
Rear: 2.4 bar = 35psi
Front 2.5 bar = 36psi
To my knowledge (and my door sticker) this is within specs, albeit the higher end of the scale, notwithstanding the softer compound I think I've got it right.
But then have been running winter & AS tyres in the UK for over 15yrs (there is no legal requirement to do so) long before it became popular here, and they've served me well on 7 different cars
So think many are blowing things* out of proportion
* See what I did there!?
#1485
#1486
Getting to the inside of the headlight cover (which is plastic) is a little more complicated.
I've not done this myself, but I understand you need to remove the headlight assembly and then separate the cover from the headlight body. There is a butyl rubber sealant holding the two pieces together and this needs to be heated in an oven or other enclosed space using a heat source (heat gun, e.g.) to be pliable enough. There are also spring clips that need to be removed. Some care is required in these steps. Overheating the plastic parts can cause melting and the butyl rubber can mar the surface of the bright parts in the headlight itself. On reassembly you need to add some butyl rubber to make up for that lost in disassembly, clamp cover and headlight together and reheat to ensure a tight and complete bond.
Others here have done this work but I did not find a good thread to link to. However, this is a very detailed video that I think is helpful.
Opening & Resealing Automotive Headlights using Morimoto Retro Rubber - YouTube
Once you have the cover separated, you can work on the inside in the same way you would work on the outside (several threads here on this) but of course you don't need to coat the inside with an anti-UV coating.
#1487
definitely not attempting a debate just commenting on an interesting subject. still not sure i understand. you said winter tires but now have said all-seasons, by winter tires did you just mean a separate set of tires for winter? not actual snow tires?
#1488
Not everything we read on forums is correct! If you look at the Jaguar guidelines for both summer and winter tyres for the 150 mph setting, they are the same for a number of different OE tyres even though the max. speed ratings are different. The mechanical characteristics (strength) must be the same. They all have to do the same job - support the car safely at 150 mph. Randomly changing safety critical parameters seems unwise to me. However, the practical safety net is that most of the world never drives at 150 mph so the real load is so much lower that you can do pointless stuff and it doesn't really matter. We are still allowed to drive at these speeds in Germany and as the loads on tyres are phenomenally high at these speeds, hence, I tend to follow the prescribed settings.
and certainly as you've pointed out, these minute distances in stopping power multiply greatly at 150mph. incidentally i'm sure they don't ignore their speed laws in the UK but we do in the US.
#1489
The great thing is my Summer's have lasted a full 4-5yrs when I've used winters for 4-5 months (Nov-Feb/March)
This is probably the best explanation, simply put winter tyres don't have studs, snow tyres do, all season are just a halfway house tbh, bu fine for a low/light mid powered vehicle.
https://www.autocar.co.uk/car-news/advice/winter-tyres
*just proving I know my cars both sides of the pond
PS: And there was me thinking it didn't get cold enough in DFW for you to trouble yourself with such things?
#1490
thanks for the info! that's correct however i have only lived here since i got smart enough to leave the northeast. i bought a set of blizzak's every winter so that i could drift around the rutted town roads of the massachusetts countryside.
MarkyUK (11-27-2020)
#1491
#1492
ah, okay, but that's not true of winter/snow tires when you are on clean asphalt as when the seasonal weather abates for a while. re-reading my first post i see that it's not clear that that's what i'm thinking of, so, my apologies. i also cannot see any reason to overinflate exceptin this case. like we both stated, this would firm up the center band again, and literally burn both rubber and money. however, because what it's firming up is an intentionally softer compound, it would give you some of your mechanical grip back. here is a demonstration of the grip loss:
https://www.youtube.com/watch?v=Lrz14n4vVkQ
Marky's actual pressures and the his guidance don't match hence it is misleading. For a 2015 XKR with the standard size 20" tyres available for both summer and winter Jaguar recommend:
Summer:
Front 2.3 bar / 33 psi
Rear: 2.5 bar / 36 psi
Winter:
Front 2.3 bar / 34 psi
Rear: 2.4 bar / 35 psi
If anything the recommendation is slightly lower, not higher! (I expect that the psi conversion is rounded differently too )
The other possible source of error can be from the actual tyre used. Some cars have the 295/30ZR20 tyre at the back. This is a stronger tyre (101Y instead of the usual 99Y) and needs less pressure: 2.3 bar / 33 psi. If you switch to the 285/30ZR20 winter tyre you do see a 2-3 psi rise but this is not because the tyre is a winter tyre, it is because it is a weaker tyre.
It doesn't matter how long people have been using winter tyres, over 20 years for me, we don't know more that the people who engineered the car. There is no correlation between winter tyre and more pressure required. Another forum myth and can be safely ignored
#1493
#1496
#1497
Hi Sean
thanks it looks absolutely fantastic I'm totally floored .
I very very careful popped out all the buttons from the rear of the fascia (obviously this was removed from the head unit first ..which is accessible from the front ) take extra care with the chrome dial there's springs on the rear .
Once all the buttons / dials removed I had the painter at work spray it for me
#1499
barnsie (12-03-2020)
#1500
