What did you do to your X150 today?
Old 12-02-2020, 07:46 PM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
I was inspired by the later model Face lifted xkr they have the black fascia / Nat unit however unavailable for purchase unless you buy the info unit in its entirety.
sure thing I’ll get pic up for you once fitted 👍👍👍
  #1502
Old 12-02-2020, 08:51 PM
Stuart S's Avatar
Received 6,335 Likes on 3,472 Posts
Steve,
Nicely done! That looks great, just like the OEM "Piano Black" trim finish. It's a more modern look. I hope you do the same thing to all the other silver painted bits and pieces so all the trim matches. You might even want to wrap the (wood veneer/spun aluminium?) dash trim in gloss black to complete the Piano Black look. Just food for thought ...
Stuart
  #1503
Old 12-02-2020, 09:13 PM
steve_k_xk's Avatar
Thanks Stuart
Good thinking , the info unit facia was the last piece of the puzzle as all my trim including the air con vents have been painted from that factory cheap looking grey to black in order to complete the look and yes it really has modernised the interior l
  #1504
Old 12-02-2020, 09:58 PM
Stuart S's Avatar
Thanks Stuart
  #1505
Old 12-02-2020, 10:58 PM
steve_k_xk's Avatar
Sorry about the quality it’s S@#thouse , although you do get a idea of how it ties in
ill get proper photos tomorrow once It’s installed correctly
The following 6 users liked this post by steve_k_xk:
paulgorringe (12-05-2020), ralphwg (12-03-2020), Sean W (12-03-2020), Stuart S (12-03-2020), TexasTraveler (12-07-2020), V7Sport (12-03-2020) and 1 others liked this post. (Show less...)
  #1506
Old 12-05-2020, 04:18 AM
MarkyUK's Avatar
Got mine back from my indy after small service, sc nose replacement, sc oil change, spark plug change and 6% ss bolt-on pulley. They also showed me that my old pulley was not stock and a smaller 7.5% performance ali one
As expected (and reported by many) 3 of the plugs were a complete pita to remove. they had to soak them overnight with plusgas. When they were all off they found them to be in pretty good shape (see pic below). They said I could get them ultrasonically cleaned and put aside for the 210k miles
They also discovered coolant around the pump so replaced that as well along with the long SC coolant pipe which was brittle (all old parts were returned to me). There was quite a congealed mess in the coolant, but I suspect it was the original stuff from factory (Ive not topped up in my ownership). So system was flushed through 3 x
One thing they did say was that they had to put in twice as much oil in the SC that they took out. Oil condition was fine (still light amber) and they couldnt see signs of a leak....so I wonder where it went?? The original coupler was in a complete state but once changed there was still a slight ratrle from the SC, they suspect some bearing damage due to lubricant being too low....which may improve with the new correct oil level.
Based on the slightly larger pulley they said that I'll be down on power...until I have the tune done that is. But that's for next year
One thing I have noticed is that coolant takes a lot less time to come up to speed...perhaps due to the congealed mess stopping circulation?
wsn03 (12-13-2020)
  #1507
Old 12-05-2020, 03:55 PM
Sean W's Avatar
Received 4,258 Likes on 2,379 Posts
Only have a pic of a trial fit at this stage however it looks great
It does look great. Is it paint for plastic specifically? Looks like it has some metal flake in it? I sense a winter project coming on for me.
  #1508
Old 12-05-2020, 04:43 PM
George Abitbol's Avatar
Originally Posted by ralphwg
Ordered a new footrest from Spain for about $60. delivered. Will show pictures when delivered and installed.
Hey, I'd be interested in that, too...kinda disappointed it's not there by default...
From which store did you get it? How is it mounted?
Thanks for the info!!
  #1509
Old 12-05-2020, 07:21 PM
steve_k_xk's Avatar
Thanks Sean that terrible eyesore of a info unit is finally gone now and it looks completely factory
Yes your correct there is some very subdue flakes in there , I was thinking if I don’t like I can have it resprayed again nevertheless I quite happy with the result .
In terms of the paint it’s just a base coat then cleared , however make sure a plastic primer is used first which should be readily available at every panel shop as it’s applied to new bumpers , side mirrors , outer door trims etc
Sean W (12-05-2020)
  #1510
Old 12-12-2020, 07:35 PM
Cee Jay's Avatar
Received 5,450 Likes on 3,214 Posts
GAAAAAHHH!!!!!!!!!
Now my poor XKR has touched SNOW! Ugh! I will now have to sell it.
(had to back it out so's to be careful while running gas pipes for a garage furnace)
The following 3 users liked this post by Cee Jay:
kj07xk (12-13-2020), MarkyUK (12-13-2020), V7Sport (12-13-2020)
  #1511
Old 12-12-2020, 07:40 PM
ralphwg's Avatar
Received 1,211 Likes on 917 Posts
I'll give you 10k for it since it has been "snowed"
  #1512
Old 12-12-2020, 08:07 PM
Cee Jay's Avatar
  #1513
Old 12-12-2020, 08:16 PM
Stuart S's Avatar
Originally Posted by Cee Jay
GAAAAAHHH!!!!!!!!!
It looks like it didn't get snowed on, and was just driven on snow. It's an easy fix, just get a new set of Miche ... uh, tires.
( an inside joke)
The following 5 users liked this post by Stuart S:
Cee Jay (12-13-2020), kj07xk (12-13-2020), MarkyUK (12-13-2020), ralphwg (12-13-2020), TexasTraveler (12-14-2020)
  #1514
Old 12-12-2020, 08:46 PM
tberg's Avatar
Received 2,579 Likes on 1,419 Posts
That's worse than a salvaged title in my book. I'd only offer $7500.00.
  #1515
Old 12-13-2020, 12:04 AM
AlexJag's Avatar
Sponsor
Wait so why downgrade your pulley?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
  #1516
Old 12-13-2020, 04:32 AM
MarkyUK's Avatar
Cos I wanted a nice shiny SS one silly...doh!!
In truth even though I am happy with the power, I'll probs go for a tune in the Spring.
SC had to come off for new oil/belt/nose so they only charged me an hours labour for fitting the new pulley, if I'd chosen to have it done at a later date would have been 2-3hrs
  #1517
Old 12-13-2020, 09:30 AM
Sean W's Avatar
Cee Jay, I'm so sorry to hear of this tragic event. It can no longer be advertised as "Never Seen Snow". I would match Ralph's offer but have to agree with Ted - totaled now imo.
What I can do though is offer you $7500 plus 2 nights and the Rmada Inn, Duluth, MN, with complimentary breakfast. Airfare not included. Blackout Dates apply - January 15 2021 - January 12 2022 - all other dates available. (FYI, that's not a TYPO, they can't afford a real Ramada Inn up there). It's been awhile for you since you last were there so I want to assure that absolutely nothing has changed in the decades since your departure:
https://www.visitduluth.com
Again, very sorry for your tragedy.
tberg (12-13-2020)
  #1518
Old 12-13-2020, 11:11 AM
Cee Jay's Avatar
I remember when that Ramada was built, the rotating restaurant at the top was a major selling point. Also, my third wife is buried in Duluth.
What a hell hole, especially between September and May.
I feel sort of like the victim of a stalking now though......
Do I know you from way back?
I got the heebeejeebees now.
  #1519
Old 12-13-2020, 11:28 AM
Sean W's Avatar
No, just in some previous thread where I mentioned I lived in Minnesota and you recalled that you lived in Duluth.
  #1520
Old 12-13-2020, 01:58 PM
Cee Jay's Avatar
Still, guess I'm either weird or old, because I don't remember many details about members in here.
guy (04-11-2021)
Quick Reply: What did you do to your X150 today?
