What did you do to your X150 today?
#1541
Absolutely not!! I took great pains to eliminate the swirls and scratches that came from the POs affinity for automatic car washes. Multi-stage polishing done with the right equipment and materials, patience, and attention to detail (paint correction to you youngsters) produces the same results
MarkyUK (01-21-2021)
#1542
Proper paint correction breaks down each section of the car into a grid and grid by grid the paint is cleaned, decontaminated, compounded to remove imperfections and flaws in the paint and clear coat brought to a maximum gloss and then sealed. It is a process that can take a specialist several days to compete depending on the severity of the defects in the paint. This is a process done on new cars as well, not just older ones.
steve_k_xk (01-08-2021)
#1543
#1544
#1545
Received 2,048 Likes
#1546
You're right, it does seem that way - however, it's a trick of the light I think. Although it could be that the PPF has a slightly greater coefficient of reflectance than the uncoated parts of the car. It almost sounds like I know what I'm talking about!
#1547
In your earlier post you said that the hood was also covered with PPF, so I’m surprised at the distinction between the two.
#1548
kj07xk (01-09-2021)
#1549
This effect is best visible in bright sunlight when IR light is abundant.
Below a picture of my old car with a full-spectrum modified camera and with a IR-pass filter (Hoya R72) in front of the lens,
you see that the rear bumper is darker compared to the rest. On the other hand, it's a mystery why the front bumper doesn't show the same effect.
#1550
Wow, what a nice picture.
My photo was taken with my iPhone 8 and post-processed using Luminar AI software, but nothing in the area under discussion was modified. Here is the camera information. CabrioBob, you are much more knowledgeable about this than I am, so maybe this will help.
#1551
Bill,
Those numbers tell nothing about IR sensitivity.
You can check it by pointing your iphone to an (old) remote control in a dark room and press a button on the remote. if it lights up on your display, it's sensitive to infrared light.
Don't use those new type of radio-controlled remotes, they don't use IR.
#1552
#1553
While I have the intake out for some mods, figured I would upgrade to the Bosch 010 S/C coolant pump, clean all 6 radiators (6... yes 6 lol), and relocate the horn. The intake mod will delete the big ducts at the front, so hopefully all this puts more air through the radiators and lowers temps a bit.
#1554
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
gkubrak (01-14-2021)
#1555
I feel like they do. Maybe not 'block' but at least prevent some spots from getting nice laminar flow. Those snorkels and the horn have a good amount of area. But will it make a noticeable difference in the end? Probably not!
#1556
Looks like my old Schumacher Battery Maintainer has its best years behind it. It's not able to keep the battery charged when the weather dips below freezing. I ordered this one. I didn't want to start another battery tender thread so I hope it dies here. Also got the ring loop connector and extension cable.
#1557
Received 1,177 Likes
And the squeak in the climate control fan is at a point where no amount of grease will silence it... guess I’ll bite the bullet and order one of those too.
#1558
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
There's a reason why CTEK brand battery maintainers are sold by new car dealers as approved accessories with OEM logos. CTEK supplies chargers to the world's most recognized manufacturers including Audi, Bentley, BMW, Camaro, Cadillac, Corvette, Ferrari, Ford, Jaguar, Maserati, McLaren, Mercedes, Porsche, and Rolls-Royce.
https://www.prnewswire.com/news-rele...Rolls%2DRoyce.
#1559
'07 XK Base
Replaced a couple of bulbs in the headlight pods. Elated to find that it was a very easy job. 3 bolts and a couple of plugs, and the pod was out. Also, the wiring was in great shape -- my current BMWs have Hellas with rotted wiring.
I only replaced the 2 W5W's with Phillips LEDs 6K, pretty bright. I use these as my daylight driving lights, and needed something more visible than the old markers. Also the 2 D1S', since they were originals and dimming. Used regular Xenon D1S, 4300K color.
Researched LED's for the D1S'. Couldn't find a LED that impressed me, and was the right color, without being overbright and blinding. As to the rest, why bother? Yellow directionals work fine. The cornering lamps do a good job as halogens.
Good engineering on Jag's part.
guy (01-23-2021)
#1560
'07 XK Base
ThIs is mine with Led DRLs:
