What did you do to your X150 today?
Old 06-25-2021, 12:14 PM
Gordo1968's Avatar
Default Changed the paddle shifters
Roger Cavling (06-25-2021)
  #1662
Old 06-25-2021, 12:48 PM
arenaej's Avatar
I had my ‘09 XK detailed, paint correction and ceramic coated...very pleased with the result...swirls & scratches gone and the finish has never looked so good. Thanks to Kendig Auto Detailing in Gap, PA.
The following 7 users liked this post by arenaej:
GGG (07-07-2021), gkubrak (06-25-2021), kj07xk (06-25-2021), Reverend Sam (06-29-2021), Roger Cavling (06-25-2021), SCXKR (09-30-2022), Sean W (06-25-2021) and 2 others liked this post. (Show less...)
  #1663
Old 06-25-2021, 01:47 PM
Roger Cavling's Avatar
Originally Posted by gkubrak
Where in the firewall did you drill through? Or did you use an existing hole in the firewall?
Hi. I used a gap above doorhinge between fender and windowframe,,, then behind rubber in to the cup’e on passenger side
  #1664
Old 06-28-2021, 01:09 PM
panthera999's Avatar
Originally Posted by Cee Jay
I didn't do THOSE fancy lights, but I did just install these fancy mirror signal lights I got from eBay... someone else posted them also which is why I bought them:
They are also black instead of clear lenses over chrome, so that's also a benefit!
https://www.ebay.com/itm/38410544092...53.m2749.l2649
CeeJay, did you have to remove the door panels, or could you install them directly via the mirror assembly?
Also, was the wire & plug accessable in the mirror?
Thanks! Panthera
  #1665
Old 06-28-2021, 03:44 PM
Cee Jay's Avatar
Received 5,450 Likes on 3,214 Posts
I pulled off the mirror caps and undid two each side torx screws, and the connector was right there. The job took like 20 seconds each side.
panthera999 (06-28-2021)
  #1666
Old 07-07-2021, 09:24 AM
asb's Avatar
asb
asb is offline
I finally got around to changing out the power steering fluid using the turkey baster method. I'm guessing the previous owner had changed it relatively recently since the fluid wasn't very dirty, but I did it for the peace of mind. For reference, I used Mobil ATF 320 (part # C2P10363) based on another post here.
tkoschinsky (07-12-2021)
  #1667
Old 07-07-2021, 10:32 AM
Cee Jay's Avatar
I just now realized that I (we) could use the oil extractor pumps that us 5.0 owners use already to remove a large portion of the power steering fluid.
I shall now use this same method to remove a fewl quarts of transmission fluid from my motorhome which is about to hit 60,000 miles and replace with new. (older vehicles hate pan drop fluid changes)
  #1668
Old 07-08-2021, 06:12 AM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
Xk finally got the death rattle , whist yes it's driven hard it is extremely well maintained with oil changes every 5-7k km ..starting to question the recommended oil specs will definitely pushing up to at least a 10w40 once I've done the chains
Another interesting note is the kit is compatible with the vantage , considering the camspecs are different (along with many other components) I would have thought they would have ran with a entirely different set-up hmmm
Haha popcorn also include in the kit !
The following 2 users liked this post by steve_k_xk:
Scott in PA (07-08-2021), Sean W (07-08-2021)
  #1669
Old 07-08-2021, 09:05 AM
tmich's Avatar
What distance has it covered?
I don't recall 4.2 oil spec - 5w30 or 5w20?
Frankly - that sort of changes can cause exact same amount of good and bad things to the car. I believe they built it really tight (at least talking about 5.0 which needs 0w20 or 5w20). Putting a thick oil can cause some problems. I would still stick to a recommend spec. But I'm not too legit. Changing oil way too often...
The following 2 users liked this post by tmich:
Cee Jay (07-08-2021), guy (07-08-2021)
  #1670
Old 07-08-2021, 10:34 AM
Cee Jay's Avatar
Yeah, changing oil specs used to be a thing, but now with engines having tighter specs and a lot more tiny holes with oil that does a lot more than lubricate, stay with the recommended oil!
jahummer (07-08-2021)
  #1671
Old 07-08-2021, 03:08 PM
steve_k_xk's Avatar
Question guys how loose are the clearances on the aj37 compared to the rest of the ajj series they run with a 10w60 .
0w20 5w30w are fantastic for reducing fuel milage however offer minimal coverage & premature wear.
Tmich I don't think oil changes too often would destroy a engine that's blizzare and based on nothing the car is driven hard and oil breaks down/ deteerates hence why the frequently of chsnges oil will also lose its original viscosity rating acting like a thinner variety as well
  #1672
Old 07-08-2021, 03:18 PM
steve_k_xk's Avatar
Tmich I'm at 125k km
  #1673
Old 07-08-2021, 10:04 PM
jahummer's Avatar
Received 2,381 Likes on 1,491 Posts
I don’t believe the tolerances of the 4.2 are as strict as the new gen 5 & 3 litre motors. I know you can use race oil in the former with no issue. The 0 spec for the newer motors was only for those exposed to freezing climes, 5w20’s
the correct spec for everywhere else.
  #1674
Old 07-09-2021, 02:19 AM
tmich's Avatar
Heard from a reputable member that he actually recommends using 0w20 anytime, due to higher viscosity of this oil. Don't have my opinion. I use 5w20, but will be migrating to 0w20 when finish current stock.
  #1675
Old 07-10-2021, 07:49 AM
guy's Avatar
guy
guy is online now
Received 1,133 Likes on 799 Posts
Call me crazy…. but I believe I can hear the difference.
Shop made the “mistake” of putting in conventional 10W30. I started her. Turned her off. Went promptly back inside to demand another change.
In he summer I like to run synthetic 5W30 anything else doesn’t sound right.
When it gets cooler (5C or less) use 0W30. And it may not matter but what’s a few bucks…. I always change the filter and replace the magnetic plug.
In anticipation of the topic…. heading to the yacht club in my polished girl…. time to get some wax on the boat, lol.
  #1676
Old 07-12-2021, 03:13 PM
Default Clean
Timeless and all that other. Im a very happy lucky owner
The following 6 users liked this post by Roger Cavling:
gkubrak (07-12-2021), Jaxxr1 (07-15-2021), peterv8 (07-13-2021), SCXKR (09-30-2022), Sean W (07-12-2021), V7Sport (07-12-2021) and 1 others liked this post. (Show less...)
  #1677
Old 07-12-2021, 03:17 PM
Default Forgot
Tip
Never!! ever make a bet about your wifes nails and your car and loose!!! You can end up like me!
  #1678
Old 07-13-2021, 10:21 AM
peterv8's Avatar
Got to meet Roger Cavling for the first time as he came by my house.
Very nice chap and a very good looking car! He has a 5.0xkr, done some nice modifications to it. He has a smaller pulley on the SC and we went for a spin with me behind the steering wheel.
Let me just say,OMG!!
Damn it was fast, never driven a car with around 550hp! My car will be of the road a couple of days til I've forgotten how fast his was!
He did warn me it can get expensive and he was right, I WANT ONE!
Thanks for the visit Roger and next time I'll let you drive mine!
The following 2 users liked this post by peterv8:
Roger Cavling (07-13-2021), Sean W (07-13-2021)
  #1679
Old 07-13-2021, 03:01 PM
wow!! A nice couple,,, thanks the same Peter. Allways fun too meet people that love to ride and all the other we speaked about,, modifying to suit our own needs
peterv8 (07-14-2021)
  #1680
Old 07-13-2021, 03:21 PM
steve_k_xk's Avatar
Peter your xk looks brilliant with the updated front end well done!
Quick Reply: What did you do to your X150 today?
