What did you do to your X150 today?
Old 08-01-2021, 07:23 PM
ralphwg's Avatar
Received 1,211 Likes on 917 Posts
My rearview camera has gone out momentarily a couple of times lately. Usually when first shifting into reverse. Current solution is shift out of Reverse then back in and all is well.
  #1702
Old 08-01-2021, 08:04 PM
Cee Jay's Avatar
Received 5,450 Likes on 3,214 Posts
I've tried that a hundred times, wiggling available harnesses, slamming down the boot lid, nothing changes anything. Course, Chinese camera, so maybe KABLOOIE
  #1703
Old 08-02-2021, 05:57 AM
Stuart S's Avatar
Received 6,335 Likes on 3,472 Posts
Originally Posted by Cee Jay
... Chinese camera, so maybe KABLOOIE
From the symptoms, it's a camera from the parts department of the US Civil Service motor pool in Washington, D.C.. Why is it a Civil Service camera? Well, sometimes it works, and ....
jahummer (08-06-2021)
  #1704
Old 08-06-2021, 06:49 AM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
Death rattle = New chains, guides, tensioners and appropiate gaskets
Where prinary chain was making contacf with head (chain had stretched 3-4mm)
Contact with primary chain
Although i purchased a high quality TSUBAKI kit i had to order oem prinary guides as they werent quite right toi much free play when seated on dowl
The journey begins
On a positive it gave me a goid chance to actusaly see how clean this engine is
All four cams timed and torqued to correct specs (120nm)
Oem primary guides
Timing cover, waterpump, crank pulley, valve covers, throttle body and thermostat housing all back on .
The following 4 users liked this post by steve_k_xk:
BlkC4t_XK14 (08-07-2021), Firm (08-11-2021), Sean W (08-06-2021), V7Sport (08-06-2021)
  #1705
Old 08-06-2021, 02:43 PM
Speedagent's Avatar
What kind of seats are those?
  #1706
Old 08-06-2021, 02:52 PM
steve_k_xk's Avatar
final fifty seats
Speedagent (08-10-2021)
  #1707
Old 08-06-2021, 05:25 PM
Ruairidh's Avatar
Default Scottish Highlands (A' Ghŕidhealtachd)
I just enjoyed driving my car.
Just resting before exploring it’s potential on an empty, straight road in the Highlands.
The following 3 users liked this post by Ruairidh:
asb (08-07-2021), V7Sport (08-06-2021), WNeill (08-08-2021)
  #1708
Old 08-07-2021, 10:53 AM
asb's Avatar
asb
asb is offline
My XKR has officially been promoted to daily driver duties (which admittedly doesn't mean much since I work from home, but I still have to run errands around town). I sold my old daily driver (Accord) because the used car market is crazy right now, and I ended up getting more than expected. The XKR will continue to be my daily driver for the foreseeable future. You'll hear no complaints from me.
  #1709
Old 08-10-2021, 03:47 PM
Roger Cavling's Avatar
Default Mods
New diffuser Adamesh
Took meter apart to fit in tray so i can close
Made a insert for cupholder to my needed buttons,, can close armrest
Hided
007
The following 8 users liked this post by Roger Cavling:
fxdwg (08-11-2021), gkubrak (08-11-2021), kj07xk (08-10-2021), miles61 (08-11-2021), peterv8 (08-11-2021), tmich (08-12-2021), Vistacom1 (10-17-2021), WNeill (08-12-2021) and 3 others liked this post. (Show less...)
  #1710
Old 08-11-2021, 09:30 AM
fxdwg's Avatar
That diffuser looks great!
Roger Cavling (08-11-2021)
  #1711
Old 08-11-2021, 11:57 AM
gkubrak's Avatar
I like it but there is no way I would ever sacrifice half of my cup holders!! lol
The following 2 users liked this post by gkubrak:
Cee Jay (08-11-2021), Roger Cavling (08-11-2021)
  #1712
Old 08-11-2021, 01:37 PM
fxdwg's Avatar
That's the smaller of the 2, so he's still good!
gkubrak (08-12-2021)
  #1713
Old 08-11-2021, 07:43 PM
kj07xk's Avatar
Received 2,023 Likes on 1,354 Posts
Finally got a bath!
Roger Cavling (08-12-2021)
  #1714
Old 08-12-2021, 11:05 AM
Default Sneek peek
Sneek peek on another projekt working on,, taillight and brakelight in the trunklights assambley
Tail
Brake
The following 2 users liked this post by Roger Cavling:
kj07xk (08-12-2021), peterv8 (08-13-2021)
  #1715
Old 08-12-2021, 12:42 PM
Cee Jay's Avatar
Originally Posted by Roger Cavling
Sneek peek on another project working on,, taillight and brake light in the trunk lights assembly
Brake
Uh, what is this for? Aren't those the stock ones?
  #1716
Old 08-12-2021, 01:10 PM
you have no lights in stock outer ring,, and stock fender taillight have lights in outer ring and i want it to contiuni around,, you will see the diffrence when its on the car
The following 3 users liked this post by Roger Cavling:
Cee Jay (08-12-2021), peterv8 (08-13-2021), tmich (08-12-2021)
  #1717
Old 08-12-2021, 02:10 PM
tmich's Avatar
If you match colors/density of OEM & moded lights - that will be a killer mod!
I really don't like the fact that inner lights are not on all the time.
Once you make - I will order this mod from you (if you can help me). Already have a pair of inner lamps waiting (really!!!!!)
The following 2 users liked this post by tmich:
Cee Jay (08-12-2021), Roger Cavling (08-12-2021)
  #1718
Old 08-12-2021, 02:35 PM
Thanks. Density is adjustable,, i have made 2 diffrent drivers for the leds that is adjustable by its own seperated with a relay so i can adjust brightness off brakelight and runninglight seperatly. And the leds,,, im using same leds that is mounted for the foglights in the assambley,,, Plcc4 smd led 4000 mcd ,, only diffrence that i wanted a 30% angle lens on mine. Yes I think too it will be a good one,, it will tell when mounted and adjusted,, saga will cont,,,,,,,
The following 4 users liked this post by Roger Cavling:
Cee Jay (08-12-2021), jahummer (08-12-2021), Jaxxr1 (08-13-2021), peterv8 (08-13-2021)
  #1719
Old 08-12-2021, 02:46 PM
gkubrak's Avatar
Will you have the dual reverse light / dual fog light functionality with this mod? Or will you still just have 1 separate reverse light and 1 separate fog light?
  #1720
Old 08-12-2021, 02:47 PM
gkubrak's Avatar
Originally Posted by kj07xk
Finally got a bath!
Where did you get the tow hook license plate thingy??? Doesn't it block the parking sensors??
Quick Reply: What did you do to your X150 today?
