What did you do to your X150 today?
#1761
The following 3 users liked this post by DGL:
#1762
Cheap alternative for clear reflector?
Love the look, but can't see spending $150 or so for 2 reflectors, since they would come from U.K.. I am going to try some 3m reflector tape on my Orange reflectors. I plan to just apply the tape to the reflector, trim and tuck in sides, but may have to remove reflector and wrap the tape around edges and remount reflector to keep tape in place. Of course, if it looks crappy it will come back off. Any thoughts?
#1763
#1765
Oh, it's too easy for someone with your skills....
https://www.amazon.com/COLOURLOCK-Le.../dp/B01DKTUJNA
Sponge it on with a few coats, use acetone on a make-up sponge to carefully wipe away the excess around the edges?????
No way am I gonna go try it with my ham-fisted hands...my wife on the other hand, might be the better person for that job.
I don't have that cool red stitching in mine, or I might just try it. Would look funny in my Oyster/Ivory Interior.
Keep on having fun,
Dave
Keep on having fun,
Dave
#1766
i'm gone try to get 1 cause the wheels do indeed really set the look off.Everybody seems to notice the wheels 1st for some reason.I may have over done it with the wheels making them look super cool😅😎 I do need to get better lighting so I can post more to show how nice they look.I'll post more pics soon whenever it's a nice bright sunny day outside and not close to dawn or a sunset
The following 4 users liked this post by Vistacom1:
#1768
#1769
#1771
#1772
CollingwoodGuy (12-26-2021)
#1773
I hope it was one of the easy to link garage door openers. Mine garage door opener is one of the finikey ones that requires an extra step in the Jag and Land Rover. So naturally there are 99 videos on how to program it....and 1 to program it so it works.
#1775
The following 3 users liked this post by DorsetJag:
#1776
Bluetooth
Hi
The Jag dealer was kind enough to enable the AUX free of charge. He simply connected his SDD diagnostics machine and enabled the feature. It took no longer than 5 minutes.
I then installed a Sony Bluetooth which operates through the AUX port - so you have to be in AUX to make/receive calls and stream music. Cost of this was around ZAR4,000 = approximately USD250. The control knob for the Bluetooth is mounted with double sided tape on the driver's armrest just rearward of the window controls.
While I was at it I had rear and front high definition cameras installed - really helps with parking - they are really small and almost not noticeable. A small 4" screen sits out of the way on top of the dash tucked up against the A pillar. They installed the cameras with a relay, which allows both cameras to use one channel. The 4" screen always shows front, but when in reverse, the screen switches to the rear view, with guide lines for parking. A switch was installed (hidden) under the dash so that I can switch both cameras off, for instance when on a long journey. This lot cost around ZAR5,000 (USD312).
#1777
DRL and winter wheels
I replaced the standard foglights with new units containing angle ring DRLs and foglights, all LED. Also put the winter wheels on. The PO had obviously used a tire firm that used an impact wrench, so one of the lugs was stuck. When I tried to get it loose the chrome cover separated from the lug so I had to strip it off before I could use an 18 mm socket on the remaining lug and a BIG handle, which worked. I found a set of 10 used lugs online at a breaker and ordered these.
#1778
Chris77 (12-11-2021)
#1779
