What did you do to your X150 today?
#1781
steve_k_xk (11-30-2021)
#1782
Vistacom1 (12-03-2021)
#1783
A lugnut....things like this take time hahahha. Delivery transport will be here in the morning. Picked up some oil and filter from FCP Euro, a sun shield and other new car bits. Next week some paint correcting. I have a nice gouge in the rear bumper that needs to be addressed, but a dark blue car hides this sort of stuff. One thing at a time. Looking for some new wheels as i hate the ones that came with it. Ill see if i can live with them but my gut says no.
#1784
#1785
Took the new car for a quick wash, removed the dealer plate and hooked up a charger to see if the battery was worth saving. If not, run to NAPA and get a new one. I have to shuffle some things in the garage to pull her in and do an oil change. One was done at Jaguar last year and 4k miles, but I still do them every year and 4k miles for longevity purposes. Reprogram the homelink, power up the sat subscription and thats about it.
WHB64 (12-04-2021)
#1786
The following 4 users liked this post by rfarmery:
#1787
Finally got the Jag back together and ran a test drive tonight. Replaced the Supercharger snout due to broken spring in the coupler. I think I had all the problems everyone has getting everything apart. It seems some of that work just wasn't intended to be done once the car was assembled. All in all, it wasn't the hardest thing I have done but I wouldn't look forward to doing it again. Replaced the following parts, some because I ruined them getting them out and some just because it is such a bear to get to them.
Part No. QTY. Description Use
KSC137624 1 O-ring Seal between air by-pass and elbow
NCC2213AC 2 Hose Connection between air bypass and intercooler
C2C11477010 2 Water Seal Seal between water pump housing and engine
AJ844638 1 Hose Between water pump housing and engine
AJ83445 1 Gasket Between throttle body and elbow
EG811062 1 Hose Valley hose, block to elbow
EG811064 1 Hose Valley hose, block to EGR
I had everything back together a few days ago only to find I had damaged the rubber reducer between the air horns and throttle body. Special thanks to GKubrak for his invaluable help in finding a place to buy the correct piece.
#1788
Well...the weather moderated - somewhat - here on Long Island, so I got a chance to tend to some niggly issues that've been bothering me for too long:
(1) "Adaptive Dynamics Fault" message. Have been tolerating this message and the harsh ride that comes with it for months. I had previously buzzed the issue with an ohm-meter and found the ride height sensor on left / rear was looking for a ground, which it wasn't getting.
Rather than trace the wire to wherever ground lug it was supposed to go to, I just tacked a wire onto the plug and ran it to a near-by chassis ground. Not the way I like to do things, but it cleared the problem. The softer ride is sooooo welcome.
(2) Moaning / whining sound seemingly coming from everywhere. Relaxed serpentine belt from pulleys, and spun all pulleys it wrapped around. Easy fix: belt tensioner - ballsy noise when spun. Ordered OEM replacement from eBay. Now have that quiet Jaguar
experience I've missed. Getting serpentine belt back on took longer than replacing the tensioner...99- plus inches of belting with a life of its own...sure my neighbours enjoyed my contortions laying on the engine bay wrestling the belt back on.
That's it for this year - next year...brakes all around.
The following 3 users liked this post by Tracee:
#1789
SCXKR (09-30-2022)
#1790
Yesterday the Bovee 1000 came in and it works flawlessly with my Android. Called Sirius and told them to cancel the $25/month subscriptions on my Range Rover and boat (me crying wolf). They came back with reducing it to $7/month and adding the XK to the mix so I went from $50 a month for 2 radios to $21/month for three. Guy said to renew it in 12 months for the same deal. Mom gave me that little life hack, so thanks Mom. Shampoo'd the lower door carpet and found some coffee splashes on the floor (gone now). Today: attack the last two sticky buttons and wire brush/paint the axles as they have some surface rust. Then Im done for a while as the car needs nothing else. New custom mats are in the mail from World Upholstery, dark blue with off white border and stitching to match the seats and exterior. Still looking for some Nevis wheels as Im not a fan of the Venoms.
#1791
I've been searching for only the two rears for about three years now. When I DO find a pair that are under $1000 for both, they are NOT the XK spec ones, but have the offset for the XF instead. Sure, nearly everyone says they fit both, but put the XF ones on an XK and they shrink into the wheel wells and look ridiculous.
For a set of four, you're looking at $2500+. Maybe time to go Aftermarket custom built.
#1792
Went for a winter drive.
Installed a Cabrio wind deflector, since the sun was out (it was 70 degrees (f ) on the first day of winter) and my GF wanted to go for a ride…well what could I say?
The deflector works better than expected, up to a tested 100mph it is awesome. Since it was such a pretty day I took a little mini drone and played around with some different shooting angles.
Life is good.
Happy Holidays everyone
wj
Life is good.
wj
The following 5 users liked this post by wymjym:
CollingwoodGuy (12-26-2021),
Hans Amstein (12-22-2021),
kj07xk (12-22-2021),
peterv8 (12-22-2021),
SCXKR (09-30-2022)
#1793
Maybe I'll try it again once the weather here can support human life in the spring.
#1794
Today I replaced ten missing fasteners on my 2009 XKR. Four engine cover quarter turn fasteners, four retaining clips on fender cowls, and two trim hook fasteners on the battery cover in the trunk.
Engine cover quarter turn fasteners – PZM100060 https://www.ebay.com/itm/255252715996
Engine cowl retaining clips – XR8-12941 https://www.welshent.com/General-Pur...ip-P27075.aspx
Trunk Trim Hook – C2P-3823 https://www.welshent.com/Hook-Ret-Ca...upe-P7365.aspx
gkubrak (12-27-2021)
#1795
Finally got the missing lug nut key from Jag ($40...not bad) and went to town cleaning, sanding off surface rust on the rear CV drive shafts. After the surface rust was gone, they got a nice coat of flat black. The underside is immaculate now. Side note: WTF is the fender liner made out of......Berber? What a poor choice of materials. Oh....added the much needed Eject button.
steve_k_xk (12-25-2021)
#1796
Wow some of this is a little intimidating
Bought mine almost a year ago. Since then I have:
-Driven it >17,000 miles
-Changed the oil
-Was rear-ended. Got the car repaired. Looks great!
-Broke the side marker light somehow. (Car wash is my best suspect) Ordered new one yesterday.
That is about it. Need to fix the glove compartment, it now has the drop problem. Need to fix the leather on the drivers seat that came unattached. The car has been pretty much worry free so far!
-Changed the oil
#1797
This is an awesome customization!
[QUOTE=pwpacp;1888386]Today, after giving her a good wash, I picked up from the upholster the rear seat tonneau cover I made. The look is so much better than I had expected!
At the outset though, I have to thank Bernie/Sherbercars for his inspiration and advice on making this thing up! He is a true genius in devising the idea to begin with.
FedEx also delivered the Mina rear wing today as well but that is a project to be completed later in the summer.
this is the coolest mod I have seen!!_
#1798
Received 1,975 Likes
Hans Amstein (12-26-2021)
#1799
kj07xk (12-26-2021)
#1800
I still haven't programmed mine. I have one of those fancy Genie door openers (opener is on the spindle directly - a jake setup?). I can't tell you how many times I have bricked that baby trying to program it to my wife's newer Toyota.
