What did you do to your X150 today?
Old 04-09-2022, 05:29 PM
Barry Leftwich's Avatar
Originally Posted by mhminnich
Was cleaning the car before my daughter took her out and discovered it had been keyed all up and down the passenger side. I don't get people.
The only answer to that is jealousy and when you that jealous,that's the type of stuff you do that's uncalled for and against the law and it's sad to be stupid enough to do that to people you don't even know.But anyway,how you gone go about fixing it or are you doing an insurance claim?
  #1822
Old 04-10-2022, 08:02 AM
mhminnich's Avatar
Not sure yet. I'm out of town this weekend, but when back I'll take a better look. I was too discouraged at the time to do much more than groan over it. Ironically, the prior xkr i had was pre-keyed when i bought it. Karma.
Barry Leftwich (04-10-2022)
  #1823
Old 04-10-2022, 06:15 PM
Man that just sounds like deja-vu all over again😮‍💨🤕
  #1824
Old 04-10-2022, 07:12 PM
mhminnich's Avatar
Good news on the keying front. It was actually more like heavy scuffing instead of gouges. I was able to buff out all but a couple of small areas using a polishing pad and finishing compound. Crisis averted.
The following 7 users liked this post by mhminnich:
Cee Jay (04-10-2022), CurtJ (04-10-2022), Hans Amstein (04-25-2022), kj07xk (04-10-2022), peterv8 (04-11-2022), ralphwg (04-17-2022), Tracee (04-14-2022) and 2 others liked this post. (Show less...)
  #1825
Old 04-10-2022, 09:03 PM
XKRAU's Avatar
Wet weekend last week, it was a good time to get dirty.
  #1826
Old 04-11-2022, 03:36 PM
Doing my best to fix a couple of busted headlight tabs on the driver's light, damaged and poorly repaired at some point before I owned the car. Plastic welding is ugly but effective so far, need to fine tune the fitment:
Busted tab before
Half the tab is missing here so I'm making the missing piece out of scrap plastic
Plastic-welded back on with steel mesh reinforcement. Needs to be sanded/fine tuned
Headlight removal is super easy
The following 2 users liked this post by BagelConsultant:
guy (04-15-2022), Sean W (04-17-2022)
  #1827
Old 04-14-2022, 09:08 AM
Finished fixing up the driver's side headlight tabs, took slightly more revision after the initial repair. Fitment is FAR better than before and the headlight is solidly mounted
The following 6 users liked this post by BagelConsultant:
Firm (04-14-2022), fxdwg (04-14-2022), guy (04-15-2022), peterv8 (04-15-2022), ralphwg (04-17-2022), Sean W (04-17-2022) and 1 others liked this post. (Show less...)
  #1828
Old 04-17-2022, 08:32 AM
Lord_Eduard's Avatar
I did some aestethic modifications:
- headlights
- side vents
- front grill
- lip kit
- wheels
In pics bellow you can see 'before and after' changes:
The following 3 users liked this post by Lord_Eduard:
guy (04-17-2022), peterv8 (04-17-2022), Sean W (04-17-2022)
  #1829
Old 04-17-2022, 09:15 AM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
I cropped that black matted photo for you:
The following 2 users liked this post by Cee Jay:
Lord_Eduard (04-17-2022), ralphwg (04-17-2022)
  #1830
Old 04-17-2022, 10:36 AM
peterv8's Avatar
VERY, VERY NICE!
Where did you buy the sideskirts and front splitter?
  #1831
Old 04-17-2022, 12:07 PM
Originally Posted by peterv8
VERY, VERY NICE!
Tnx. It's just universal one, measure the car and search ebay for appropriate size and shape
  #1832
Old 04-23-2022, 10:05 PM
Tracee's Avatar
New brake pads and rotors on rear. Wasted a lot of time getting the wind-back tool to work; my bad - just not thinking. Interesting thing, and shouldn't be surprised with a used car with 3(?) previous owners, found the rear brake wear sensor hanging loose, but it was incorrect for the rear - was a front wear sensor. Did a previous owner buy the wrong sensor, find out that it didn't fit, so just left it hanging there? Or didn't have the correct one and left it in place so the dash warning light stayed off? The adventures of used cars, and discovering previous "fixes" and making things right...
  #1833
Old 04-24-2022, 08:51 PM
mizzleman's Avatar
Topped off rear diff fluid and added seal conditioner...hopefully that will stop the leak at the left axle shaft.....
  #1834
Old 04-26-2022, 02:52 PM
Sean W's Avatar
Received 4,219 Likes on 2,367 Posts
Replaced the front lower lateral and forward control arms. I used Eurospare for the banana arms. Still too fricken cold to drive on summer tires. It hasn't hit 40 today so yet to test drive it. She'll need an alignment.
Next is to add CarPlay and Cabrio Bob's ashtray gauge display. Both use the same Cigar lighter feed. My lighter housing is DOA. I've never tried it, but the housing was shot so ordered from Terry's Jaguar and will resume the Cabrio Bob's install when the parts are here. Cambo's CarPlay set up takes advantage of the convenience mode wiring of the Cigar lighter so I'll start working on that in the interim as there are no warm days on the horizon.
  #1835
Old 04-26-2022, 07:24 PM
gctippett's Avatar
Still in the garage
Sean W (04-26-2022)
  #1836
Old 04-27-2022, 04:09 AM
guy's Avatar
guy
guy is offline
Received 1,103 Likes on 776 Posts
Be careful @mizzleman ! The fill port on the differential is not the fluid level. I would just empty it and put in the specified amount. The issue is volumetric gain which occurs when the fluid is heated.
The sealant ma work. But the diff gets hot. I think a new seal may be in order.
  #1837
Old 04-28-2022, 06:54 PM
XKRAU's Avatar
I recently did my diff oil on a XKR4.2 and pumping 1.3litres of gear oil that's when the oil started to drip out at the fill hole. Wait till it stops dripping and I capped her off. So the fill hole is the fluid level.
The following 2 users liked this post by XKRAU:
gctippett (05-06-2022), steve_k_xk (04-28-2022)
  #1838
Old 04-28-2022, 07:48 PM
steve_k_xk's Avatar
Received 1,548 Likes on 895 Posts
Standard practice ^^^ . Nice one Chris !!
Which brand and oil did you go for
  #1839
Old 04-29-2022, 07:21 PM
V7Sport's Avatar
Added DRL to my 2008 XKR. Using SDD V130 and a Mongoose, set DRL to Canadian spec. Worked like a champ.
CEL indicator came on but cleared after a short drive. Happy camper now!
The following 4 users liked this post by V7Sport:
gctippett (05-06-2022), kj07xk (04-29-2022), Sean W (04-29-2022), steve_k_xk (04-29-2022)
  #1840
Old 05-05-2022, 02:33 AM
XKRAU's Avatar
I went with Amsoil 75w-140 severe gear oil.
https://www.amsoil.com/p/severe-gear-75w-140-svo/
Been proven to run cooler without the gear oil breaking down in extreme conditions. It gives me a safety margin especially the way I drive.
Overkill yes, but at least I don't need to worry about it for another 15 years!!
steve_k_xk (05-05-2022)
Quick Reply: What did you do to your X150 today?
