What did you do to your X150 today?
#1881
#1884
Had to have a major brake repair, the brake booster failed. Pedal could be depressed but would stay down. braking was actually good, too good. Sometimes you could lightly touch the brake and it felt like you were doing a panic stop. People behind me would follow suit. So I had to order the booster, was on back order, took 2.5 weeks to arrive from UK. When the work was being performed by my Indie, the mechanic noticed the old booster was 1/2 full of brake fluid, which had been leaking out of the master cylinder. So now I had to get a new master cylinder too. Cost was outlandish but I have a new brake system that works fine now. I also got new rotors and pads installed.
The following 2 users liked this post by BlkC4t_XK14:
kj07xk (06-03-2022),
steve_k_xk (06-03-2022)
#1885
BlkC4t_XK14 (06-03-2022)
#1886
Happy to hear you got it all squared away... I'm always worried to do any big jobs on the XK since the local dealer here is usually not very accommodating. Local indie shops are hit or miss. I see you're in NY... you have a local indie that works on these cars and isn't out to use you as an ATM ? I'm over in LI myself...
XK to him since the warranty ended. Nick owns several exotics and takes care of all. Porsche, Aston, RH drive Toyo Supra '89 just to name a few. I have seen them fix late model BMW, Merc, Porsche, VW, Audi, LR, Viper.
myexcursion (06-04-2022)
#1888
#1889
A/C Duckbill checked and lubed
Today, I followed Gr8Brit's procedure to come in from the top of the car and lube the duckbill drain with spray silicone. Although, I had to also remove the Intake "y" Resonator on top of the throttle body (4.2 S/C) to give a few more inches of clearance as my arms were just a bit short. Once done I had just enough reach to check out the duckbill and found out it had been sliced on one side. I lubed it up with the spray silicone and could get about 1/2" of my finger in it to make sure it was open.
Fortunately, I knew from the CARFAX history of this car that the PO had taken it to an Indy shop (not Jaguar) for this issue about 3 years ago and they had removed the trans to perform the repair. I assume they are the ones who sliced the duckbill.
Thanks again to Gr8Brit for posting his procedure years ago. It still comes in handy and saves a good amount of cash and frustration.
The following 3 users liked this post by mizzleman:
#1890
Well, nothing special today, besides driving it to the office...but this weekend I did both the glove box damper fix (one of the previous owners had fixed it already, but the plastic arm where the screw was attached had broken off...) on Saturday and the duckbillectomy on Sunday. Both a PITA, but now it's done. Didn't manage to properly cut off the duckbill but it's been severed sufficiently to do the job. And my kitty now pees where it should, i.e. underneath it, not in the passenger footwell.
But now the airbag warning light is turning on and stays on shortly after startup...
PS: this forum definitely needs a "facepalm" smiley...which I would then have used above...
#1891
George Abitbol (07-25-2022)
#1892
Received 2,059 Likes
The following 3 users liked this post by kj07xk:
#1893
#1894
Sean W (07-25-2022)
#1896
The following 3 users liked this post by miles61:
#1897
Replaced the engine air cleaners and cleaned the MAFs. Changed the cabin filter. Filters had the jag logo on them, I suspect they had never been changed. Existing MAFs are FoMoCo parts.
Checked the front brakes, looked good! Front lug nuts had rubber sections in them? What for?
#1898
growler looking in wrong direction
Picked up a fast leak in a rear tire, determined that the spare needed to be used to get to Discount Tires (25 mile trip one way)…wow the tire/wheel bounced so bad that 40 mph was the max I could drive, so no issue with overheating the space saver spare.
Had all four balanced along with the repair, the car feels a bit better now, the tires only have @ 4K on them. Got home and saw that I now need to pull all four wheels and realign my center caps so the growler points to my valve stem.
It’s the little things you know!
wj
wj
#1899
Vistacom1 (08-16-2022)
