What did you do to your X150 today?
Old 01-28-2023, 07:48 AM
jahummer's Avatar
Received 2,373 Likes on 1,487 Posts
Originally Posted by Cee Jay
I also had to search when I first needed a filter wrench as 'normal' places didn't have the right size. I finally ended up ordering from a NAPA and got it a few hours later. And whattaya know, it was the right size but was still loose enough to slip. I wrapped some heavy plastic around the housing and it worked well enough to be used.
Maybe I'll mill a good one out of a block of aluminum.
This one’s also a perfect fit and very well made
FIRSTINFO 3/8" Drive 90.2mm 15 Flutes Oil Filter Wrench, Compatible with Land Rover & Jaguar - Fits 3.0L & 5.0L Gas Engines
https://a.co/d/9JrMvNi
Cee Jay (02-06-2023)
  #1942
Old 01-28-2023, 08:37 AM
kj07xk's Avatar
Received 1,980 Likes on 1,329 Posts
When the kids are finally old enough to know how to cautiously clean the Jaggy 😄
Doggy doesn’t seem to be too enthusiastic about it:
steve_k_xk (01-28-2023)
  #1943
Old 01-28-2023, 09:36 AM
Sean W's Avatar
Received 4,222 Likes on 2,368 Posts
Post
You're a braver man than me Steve. Son: OK Dad, I'm turning on the water
Me: No no, you're doing it all wrong. Here give me the hose.
The following 2 users liked this post by Sean W:
Cee Jay (02-06-2023), Wm. Lyon (02-01-2023)
  #1944
Old 01-28-2023, 03:14 PM
steve_k_xk's Avatar
Received 1,550 Likes on 895 Posts
Hahaha been down that path before but I was watching like a hawk !!
  #1945
Old 02-01-2023, 12:53 PM
Wm. Lyon's Avatar
Default Exhaust Tips
I've always liked dual exhaust tips and have installed them on almost every car I've owned. Had these installed yesterday. They're actually a bit larger than I originally imagined but, the ones I had bought on ebay looked ridiculously small in the opening. Stock "back box" still but thinking about replacing the mid mount muffler with an "X" or "H" pipe for a bit more rumble.
The following 4 users liked this post by Wm. Lyon:
resident_fng (02-01-2023), Sean W (02-02-2023), steve_k_xk (02-02-2023), Vistacom1 (02-01-2023)
  #1946
Old 02-02-2023, 06:42 PM
steve_k_xk's Avatar
They look fantastic always found the stock xkr tips to be on the small side and do not fill the valance up .
In regards to X-pipe vs H-pipe ,
The best way I can describe it is the x-pipe has a higher pitched sound more like a flat planed crank powered vehicle, whilst the H-pipe has a deeper rumble note to it .
Wm. Lyon (02-03-2023)
  #1947
Old 02-02-2023, 06:51 PM
arenaej's Avatar
can you share the source for these tips? Thanks.
steve_k_xk (02-03-2023)
  #1948
Old 02-03-2023, 01:36 AM
Wm. Lyon's Avatar
Thanks for the kudos and information! 👍
The following 2 users liked this post by Wm. Lyon:
Boga (02-05-2023), steve_k_xk (02-03-2023)
  #1949
Old 02-03-2023, 01:40 AM
Wm. Lyon's Avatar
Sorry, they are some the muffler shop had, when the ones I had brought looked too small in my opinion.
  #1950
Old 02-04-2023, 07:44 PM
ralphwg's Avatar
Received 1,209 Likes on 915 Posts
See the attached picture of the Mina tips on my 2013 XKR
The following 2 users liked this post by ralphwg:
Privilegedjaguar (05-18-2023), Sean W (02-05-2023)
  #1951
Old 02-05-2023, 09:41 AM
Sean W's Avatar
@Wm. Lyon Would you ming asking them? They look pretty darn good and it would be cool if we could get our hands on a set.
arenaej (02-05-2023)
  #1952
Old 02-05-2023, 10:53 AM
Joe7Bros's Avatar
Today's "Upgrade"
The following 5 users liked this post by Joe7Bros:
gmuirnz (02-05-2023), panthera999 (02-13-2023), SCXKR (02-08-2023), Sean W (02-05-2023), Wm. Lyon (02-05-2023)
  #1953
Old 02-05-2023, 04:22 PM
Wm. Lyon's Avatar
Unfortunately, the shop is about an hour away from where I live. But, next time I'm in the area I'll swing by and ask.
  #1954
Old 02-05-2023, 06:21 PM
mhminnich's Avatar
I got ambitious and pulled the headlamps from the XKR to clean the projector lenses. That didn't go well as there is scarcely any access to the backside. I did manage to lose a washer hose clip and break a headlamp tab, so it wasn't a total loss. 🫤 after that, I gave her a much needed bath ,which revealed new parking lot dings and a bumper scuff. It's been a day! At least the weather was great!
The following 3 users liked this post by mhminnich:
McJag222 (02-05-2023), panthera999 (02-13-2023), Sean W (02-05-2023)
  #1955
Old 02-06-2023, 10:12 AM
Cee Jay's Avatar
Received 5,364 Likes on 3,176 Posts
Really no benefit in the 4.2 xkr as the supercharger will max boost long before the 7400rpm but on the n/a version it picked up 2mph and .2 e.t on the 1/4 mile
Yeah, I'm not ever going to do this:
The following 2 users liked this post by Cee Jay:
guy (03-02-2023), Hans Amstein (02-13-2023)
  #1956
Old 02-06-2023, 10:37 PM
BlkC4t_XK14's Avatar
I did the Mina Gallery on MY14 XK Touring. That has the NA/5.0 liter engine. You get the quad exhaust, the rear valance and it is a true 2x4, not just tips. Two pipes come into a smaller muffler and for pipes come out. These are all aircraft stainless, polished and fit exactly. they have center pipes too or you can make your own or leave the ctr silencer in. I left mine in. It has a nice burble at Idle and a good roar at start up and when the right pedal is pressed down hard.
The following 4 users liked this post by BlkC4t_XK14:
Firm (02-09-2023), ralphwg (02-06-2023), Sean W (03-02-2023), Wm. Lyon (02-07-2023)
  #1957
Old 02-07-2023, 11:03 AM
Wm. Lyon's Avatar
Congratulations! Looks great!👍 Any chance you could post a sound/video clip?
  #1958
Old 02-07-2023, 11:26 PM
steve_k_xk's Avatar
No point on the forced induction they run out of steam at 6500rpm different with the n/a - more rpm = more bhp .
These engines share the same valve springs , valves as the AM 4.3 vantage (4.7 larger valves) and have also been tested up to 7500.
  #1959
Old 02-08-2023, 07:46 AM
SCXKR's Avatar
Grabbed these seat belt garnishments off Amazon for under $20. Just wanted a little color on the interior.
The following 2 users liked this post by SCXKR:
Marco75 (02-12-2023), Sean W (03-02-2023)
  #1960
Old 02-08-2023, 08:34 AM
I attempted to post a sound video clip but no sound only visuals.
Quick Reply: What did you do to your X150 today?
