What do you think of these wheels?
First of all I am not a fan of most aftermarket wheels. I love the staggered 20" Sentas I have on the car now but I am not crazy about the wheels spacers I am using now and I would like to have wider tires on the rear for increased traction.
I found these wheels as a perfect fit, with offsets that would eliminate the need for spacers to bring the wheels close to the edge of the wheel openings.
What do you think of the design on a lunar grey XKR coupe?
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/75487-what-do-you-think-these-wheels-aspire-1386790776.png?dateline=1394466494)
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/75488-what-do-you-think-these-wheels-black-chrome-machined-face-1386790776.png?dateline=1394466494)
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/75489-what-do-you-think-these-wheels-ace-aspire-wheels-mercedes-s550-1.jpg?dateline=1394466494)
Jahummer:
You may want to take a look at this thread which I wrote reference aftermarket wheels for the Jaguar XK/XKR/XKR-S.
The thread Post #1 is very detailed on my experience. It will take about 10 minutes of your time to read the thread and watch the videos.
My Braelin BR02 wheels have arrived and will be mounted on Thursday of this week with photos of my XKR convertible with the new wheels mounted. They are a perfect fitment.
Check this out:
https://www.jaguarforums.com/forum/w...-brand-112076/
Here is what the wheels look like mounted on a 2009 Jag XKR Coupe. This owner took my personal suggestion, and these are the same wheels that I ordered. Turnaround time from production to delivery is about 2 1/2 weeks.
Check this out:
Stormdk (03-10-2014)
Jahummer:
Check this out:
Check this out:
Thank you, yes I did read your thread. These are the same brand you chose and the same options of custom bolt patterns and custom offsets.
![](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/75494-what-do-you-think-these-wheels-ace-convex-hyper-silver-machined-face.jpg?dateline=1394467594)
I believe the ACE Convex comes in a 10.5 x 20, and my order for the Braelin BR02 was a 10" wide wheel in the rear and 8.5" in the front.
I ordered them from Canada and because of the exchange rate to the Canuck Buck, it was lower priced for me to go that way.
Yes, Ace will drill the bolt pattern, and the center bore for you. I ended up with the Braelin BR02 due to the superior service that Fastco and the President gave me, along with Ian and because of the price. I did not want to put my 285/20 tire on a 10.5" wide rim.
If you decide to go with the Ace, and since you live in Florida, WheelTech (Jon) in Tampa, Fl can get the wheels for you.
Hope this helps.
jahummer (03-10-2014)
Then, I coated the outside of the wheels with the Pinnacle Black Diamond Wheel Coating to repel future dirt and brake dust. This process will help reduce dirt and brake dust substanially.
We all need to remember when washing and detailing any car, wheels take time and patience to clean. The wheels are what helps make any automobile so nice looking. Yes, it might take some extra effort to clean, but using the correct wheel brushes, cleaners, and protectents will make the job so much easier.
The best way to clean a wheel is to remove it form the hub, so the inside can be cleaned properly, but most car owners will NOT take the time to jack up the car and remove the wheels for cleaning. So ultimately, only the outter portion of the wheel surface gets cleanly effectively and properly.
Consider removing the wheel form the hub, cleaning well and applying a brake dust barrier and dirt coating to the inside of the wheel rim. This will make cleaning and your life so much easier in the future.
Since my new wheels arrived just arrived and have NOT been mounted, I sprayed the inside with Meguiars Hot Rim Brake Dust Barrier product giving the inside wheels several coats. I also installed new TPMS's.
EDIT: HOW DO I DELETE THIS ATTACHMENT?
I agree, it's hard to beat 20" Sentas. For me it would be very important on how much these wheels everyone is mentioning Cost??
I calculated that it was like 30-40 hours a year that a challenging set of wheels can add to my auto detailing; not worth it.
My cars get washed about 40 times a year by me, and times that by 2 is a lot of washing. No way am I taking the wheels off 80+ times a year. I can tell you, I do use 4 different brushes, 2 different sponges, and mitts to clean the wheels. Even the back side looks very clean; calipers- great.
I am suggesting that you remove the wheels, spray them with a dust barrier, brake barrier coating, and this will keep the inside so much cleaner. Pressure from a hose, or high pressure car wash will simply wash away the debris. Perhaps you pull the wheels 3 or 4 times a year if needed.
Also keep in mind, that some inside wheels are black while others are chrome or a machined aluminum. The black won't show the dirt and brake dust but the chromed or machined alloy will.
To suggest to anyone to remove the wheels 80 times per year would be a bit crazy and I would never suggest that.
Here's my actual invoice for my wheel purchase which includes everything delivered to my door via UPS....
This invoice is for the Braelin BR02 Hypersilver w/ Machined Face
Description Quantity Unit price Amount
BR02-2085-31KG+35C633 - Braelin BR02 (Hyper Silver with Gloss Machine Face) Wheels 20X8.5 5/108 35mm 63.30 2 $335.99 $671.98
BR02-2000-31KG+25C633 - Braelin BR02 (Hyper Silver with Gloss Machine Face) Wheels 20X10 5/108 25mm 63.30 2 $338.99 $677.98
Subtotal $1,349.96
Shipping/handling $186.28
Total $1,536.24 USD
Terms and conditions
Richard Z 575-XXX-XXXX
2009 Jaguar XKR Portfolio. Fitment guaranteed.
These Braelin BR02 wheels are beautiful wheels.
I will post photos on Thursday once mounted on the car. I highly recommend the Braelin brand.
Braelin Alloy Wheels
RedRider48 (03-12-2014)
Dunno what size those rims are in the Mercedes picture in your original post, but they look too big/tasteless to me.
As you asked for an opinion, whatever rims you choose, I suggest avoiding going over 20", as its seems surprisingly easy to overdo it and quickly turn your stylish classic into something that looks ghetto-trashy.
To replace OEM Jaguar wheels in a 20" staggered setup, the typical cost is $4000+. When you can buy an aluminum monoblock wheel that can now be custom fitted to your auto for under $1500 represents at great value. The only other alternative is exchanging your current Jaguar wheels via a wheel exchange vendor, who takes your old wheels and replaces them with refurbished wheels of the exact same style. Typical cost is $800 to $1000.
Some of the better sellers/producers of wheels now have the capability to mill, drill bolt patterns and center bore wheels for guarenteed fitment. Thus, there is no need for the use of wheel spacers in order for an aftermarket wheel to have proper fitment.
I spent 6 to 9 months researching, calling wheel producers before I found what was an acceptable style, design and price point to fit my 2009 Jaguar XKR. I had to take extensive measurements in order to obtain the proper fitment which is critical. I had a company Fastco.ca that was willing to work with me for my quest to find a wheel that fit. For myslef, it was extremely difficult to find an aftermarket wheel that would fit properly over my oversized UK Alcon oversized brake calipers that are an option on many Jaguar models.
Even the Coventry wheels made for the Jaguar brand exclusively and that are made specifically for TSW Wheels would NOT fit my Jaguar.
No one has to sacrifice any quality by purchasing a monoblock aluminum alloy wheel. I personally see no need or reason to spend $4000 to $5000 for a set of wheels for these Jaguar cars or any other brand. The only reason would be if you like that type of wheel which is usually considered a 3 piece wheel.
Keep in mind that the majority of the monoblock wheels are made in Asia predominately China under strict standards. Just because they are Chinese made does not make them inferior in any way.
All GM wheels are produced in China for GM, which includes Corvette wheels.
It isnt only how the wheels look standing still but how they look in motion. Beautiful wheels that are standing still can look horrible with the car rolling. Just a thought. I think they look gourgeous on the above car
