wheel specifications as our Jags? I ask because I hear Volvo and Ford may have similar wheels. And...I'd like to make some changes at some point.It is enough to just focus on the offset, diameter, lug pattern and width of the wheels?
yup everything you listed plus the center bore. then, fit the figures into a calculator that can give you an educated guess at fitment/interference, given some measurements that you take yourself on your car. i used the first "wheel size calculator" that came up on google. i don't think there's any true guarantee even after all this diligence, but if you do all that accurately then there won't be much left to do to fit the wheels you end up getting; either a small spacer or maybe a tiny bit of machining.
And some Land Rovers like the Evoque and Velar but more importantly is offset, not all of the makes and models have the same offsets which will affect how far in or out the wheels sit from the hubs.
F355, f360, f430, 550 maranello all staggered and run good offsets to fit the 4.2
Centre bores are 67.1 mm and obviously stud pattern is the same as ours 5x108.
The problem with focus and Volvo wheels is you won't be able to get them staggered most.only go up to a 8.5'' width that also goes for landrover in regards to unable to get staggered.
These bbs challenge wheels sure do remind me of the 4.2 vortex wheels Vortex wheel
