What Part Is This???
i had received a P003E error and learned that there is a LR TSB for this related to an oil restrictor issue, this restrictor is in the front of the cylinder head just below the input phaser.
it seems the CPS Camshaft profile switching (CPS) solenoids has some kind of insert which I suspect may also be part of the oil flow process. Does anyone know as i cant seem to find any details.
ExKayRick (03-10-2021)
Thanks and agree but the workshop and other docs do not describe what part this is or its function. The workshop has the image of the component but does not reference it. My research yesterday indicates that it might be an oil control valve or a one way control valve. im looking to understand the function of this device to see if it could be a possible cause of my code.
Thanks, i am well aware of how the CPS works, my questions is what does the image i had put in above do, whats its function. Below is the text and it does not state what this device does. That is what i am looking to determine, what is this device, is it a check valve or a one way valve and what happens if there is an issue with this device? "The CPS (camshaft profile switching) system switches the intake valves between two cam profiles which have different lift
and period. The low lift profile improves driveability and emissions at lower engine speeds. The high lift profile improves
power and torque output at higher engine speeds.
The intake camshafts have three lobes for each valve. The two outer lobes have identical profiles that produce the high lift of
10.53 mm (0.415 in.). The central lobe produces the low lift of 5.50 mm (0.217 in.). Switching between cam profiles is
performed by a switchable tappet on each intake valve. The switchable tappets are operated by engine oil controlled by a
CPS solenoid on each cylinder head. Operation of the CPS solenoids is controlled by the ECM.
Camshaft Profile Switching Solenoids
The CPS solenoids control the supply of engine oil pressure to the locking pins in the switchable tappets, to switch the
tappets between the two cam profiles.
A CPS solenoid is installed on the rear of each cylinder block. Each CPS solenoid has a pintle installed in a sleeve, which
incorporates oil inlet and outlet holes. The sleeve is installed at the junction of oil galleries in the cylinder head, with the oil
inlet and outlet holes aligned with the galleries. Movement of the pintle in the sleeve controls a connection between the oil
galleries. When the CPS solenoid is energized, the pintle connects an oil supply gallery to the gallery along the outboard side
of the switchable tappets. When the CPS solenoid is de-energized, the oil gallery along the outboard side of the switchable
tappets is connected to drain.
