what is the plastic box behind the rear speakers?
i am installing aftermarket rear speakers in my 07' xkr, and the back of the speakers are hitting that semi-clear plastic box directly behind them. does anyone know what it is and what it does? i'm asking because, if it's not a very crucial component of the car, i'd like to cut into it and give the speaker the clearance that it needs. that will save me having to order the correct spacers and have the back of my car all apart for a few days. any info would be very appreciated!!
So Multistrada, what did you decide to do with your setup? I saw your other thread and was following with interest. I too have the mid range woofer hidden under the footwell.
The first time my wife rode in the car, she asked me if there was something wrong with the "stereo".
I've lost too much hearing to focus on high end solutions. I don't want a 10" subwoofer but feeling base is still important to me. (again, hearing loss)
$500> improvements are wasted on these deaf ears, but I have to believe there are low end cost door speakers that could improve the sound. I want to crank up the noise without frightening the neighbors.
I reached out to another member who installed some new door speakers and tweeters with crossovers but he didn't have the center speaker or amp. He said that alone made a world of difference and roughly two sets for $200. JBL GX-600C speakers
I'll probably follow his lead, but would like to solution the mid range woofer without installing a different amp.
For you audio experts out there, why do you suppose the mid range woofer was sealed behind a panel next to the amplifier? Is it located there as an afterthought? Is the panel to suppress road noise? Could slotting the panel allow for some semblance of bass to come through?
I don't need all base, just more base. Clearly not an audiophile but appreciate you all tolerating my ignorance.
The reason it's sealed is because the sound that comes from the back of the driver is deleterious. Most manufacturers dont take this much care. It shows that Jaguar meant well but the 'committee' got it wrong.
Here is the good news, we supply the best of the best and do the R&D. We can solve this for jaguar. Don't settle for one size fits all aftermarket drivers.
If someone can send is their driver we can recommend a proper solution at much less money than gimicky aftermarket stuff.
Sean W (05-25-2016)
Sean W.,
(Not an audio expert, just a bit of a fan(atic)). Multistrada74 has just done what you're considering and can provide recent first hand perspective on switching out speakers. That speaker next to the amp in the passenger-side footwell is a small subwoofer intended to fire into the cabin without talking up too much room. Slotting it may give you a bit more volume as the driver needs to push air. You might try to see whether a sturdy grill would work. Whatever you do, enjoy it; it's worth it.
Sean W.,
Last edited by bart_redline99; 05-23-2016 at 09:10 PM. Reason: I misinterpreted the question..
Sean W (05-25-2016)
