What tool tightens the metal collar below the shift knob?
Old 01-20-2024, 07:35 PM
howdoyousayjaguar's Avatar
Originally Posted by panthera999
Remember it's easy to grind down a square tip (widely available) or a larger round tip. Or a file if you feel like an Amish farmer. I found the right size C-wrench tip to be a tough search.
Thanks. Yeah, I couldn't find it at AutoZone or the home Depot. I tried with pliers on some rubber but they just kept slipping down because the metal tapers. I'm also not manly at all with tools so maybe there's a better way to use the pliers.
Cee Jay (01-25-2024)
Old 01-20-2024, 08:52 PM
arenaej's Avatar
Here ya go
Amazon Amazon
The following 2 users liked this post by arenaej:
howdoyousayjaguar (01-22-2024), jjackerson (02-05-2024)
Old 01-20-2024, 09:48 PM
panthera999's Avatar
Originally Posted by arenaej
Thats the one.
Old 01-22-2024, 12:40 AM
You are a gentleman and a scholar. Thank you so much!
The following 2 users liked this post by howdoyousayjaguar:
arenaej (01-22-2024), Cee Jay (01-25-2024)
Old 01-22-2024, 06:42 AM
I seem to remember that that metal collar has a opposite thread? Can anyone confirm or correct? Thanks
Old 01-23-2024, 09:02 AM
V7Sport's Avatar
Righty tighty, lefty loosey. I haven’t used a wrench to tighten. Back off the shift knob about 1/8 to 1/4 turn, then tighten the collar by hand. Hold the collar in place and tighten the knob into the desired alignment which jams the two together. A touch of blue locktite on the threads is recommended.
The following 2 users liked this post by V7Sport:
howdoyousayjaguar (01-23-2024), Sean W (01-23-2024)
Old 01-24-2024, 05:26 PM
Sadly this is not working for me. The collar only locks in place when it's screwed all the way on, leaving the knob facing the wrong direction. It's quite possible I'm doing it incorrectly, but after 40 or 50 attempts, I feel like I've tried everything. For the time being, I've just removed the collar.
  #28
Old 01-24-2024, 05:32 PM
For anyone with the same issue, the tool doesn't work for this. It's adjustable but only locks in place at the widest setting, and it only has one pin rather than two so it can't turn it. I'm wondering if the collar is worn down because it's loose unless screwed all the way down, which leaves the knob facing the wrong direction. Currently I'm going collar-less, but I'm not happy about it.
Old 01-25-2024, 07:03 AM
V7Sport's Avatar
Perhaps the threads in the collar or on the lever shaft are stripped. I’d take things apart for a close inspection.
You might have the collar drilled and tapped for a grub screw to be able to lock it in place.
  #30
Old 01-27-2024, 01:33 PM
Just ignore everything I've said. As I was showing my dad the issue, it just semi-magically locked into place. I must have been doing it incorrectly the first 100 times.
Thanks again guys.
The following 3 users liked this post by howdoyousayjaguar:
Cee Jay (01-27-2024), RichardS (01-27-2024), V7Sport (01-28-2024)
  #31
Old 01-27-2024, 04:04 PM
dangoesfast's Avatar
A variation of the old "Nut that holds the steering wheel" joke came to mind when I first saw the thread, now I'm annoyed I didn't post it cause it turned out to be the right answer....
Which tool tightens the metal collar below the shift knob?
The one sitting in the driver's seat!
howdoyousayjaguar (01-29-2024)
SamtheSham
07-17-2019 07:11 AM
mvivio
04-30-2016 08:25 AM
michaelodonnell123
02-27-2016 07:01 PM
JessN16
12-03-2015 11:59 AM
josh_77073
04-13-2013 11:07 AM
Quick Reply: What tool tightens the metal collar below the shift knob?
