What is the Verdict on Engine Oil Filters
Two thoughts:
Isn't Mahle a company manufacturing OEM filters? If so - they are 100% the same.
How to compare one oil filter to the other? I believe the only qualities we can compare are the visible factors like "perceived" quality, fitting etc. Where in reality a better filter means the highest flow with the highest "cleaning" capability (which are opposing to each other )
Frankly I would not expect any outcome of this discussion. Choose reputable brand and replace it often
MarkyUK (11-06-2020)
In terms of oil filters it really needs to meet or exceed to maximum flow rate of the jaguar oem, whilst still doing a good job of filtration. I can recall around 15 years ago there was a trend for people with classics such as xk120 'upgrading' to modern metal 'spin on' type filters. The kits were quite dear, often over £100, and sold on the basis of simplifying oil changes going forward. If however you read the spec, in some cases maximum flow rates were half of the jaguar original!
The cost difference between OEM and other brands isn't worth it IMO. When the car is on a lift, I want to see a Jaguar everything; no Napa and Pep Boys.
jahummer (11-05-2020)
Huntervision (11-05-2020)
If in doubt, cut a few different brands open and see how they are made. Mini brands that sell filters do not manufacture the filters themselves but have other companies produce filters for them and those companies tend to use the same components depending on the brand placing the order. Sometimes youll find OEM filters have slight differences than the aftermarket brands but that doesn’t necessarily mean they’re better or worse so it’s always good to look.
heres a good reference https://bobistheoilguy.com/forums/th...ilters.176344/
I've always used K&N oil filters. They're high quality and Iove the fact that they have a socket adapter on the bottom them to make installation and removal a breeze (especially if your oil filter is in a tight area).
#31
A few years back I found a very thorough, scientific test of oil filters online and Mobil 1 was rated the best. I'm not sure where I saw it but you may can dig it up. Mobil 1 is consistently rated the best oil as well and their prices reflect it for both oil and filters. They are easy to find in most any parts store or online for any vehicle. Most of the other brands are owned by some corporate overlord and the only difference is the labels they slap on them. Purolator. Fram. Etc. Crap. BTW Jaguar does not make their own oil filters.
This is not the study I referred to earlier but another good one that came to the same conclusion..
https://www.austincc.edu/wkibbe/oilfilterstudy.htm
#33
Indeed, as I said in post #7....the response was "to save money" and to that I say what money? OEM filters are cheap, not to be rude but if saving a $1 is that important in this example then there are other problems that need looking after...
The following 4 users liked this post by jahummer:
#34
#35
Edit: looking at mosesbotbol's subsequent post, I should clarify my reference to various filter comparisons was the non OEM type.
#36
The Jag XK filter "fits" on the Aston Martin V8, but the spring rates inside are different. If something happens due to the filter and it's not an AM filter; be ready to lick wounds. I'd imagine it's the same with Jaguar. Filter causes an engine problem and Jaguar will be quick to point out the brand filter.
Someone on my AM forum had an AM oil filter implode or something like that. Destroyed the engine & AM paid for a new engine. Fram & Wix are not going to pay for your engine if the filter failed or wasn't adequate.
#38
Cabin air filters are a different matter. What's the worst thing that can happen? The OEM Jaguar filter isn't worth the cost, IMHO. Just be sure to change the aftermarket filter annually.
From Ebay:
My car, my money, my choice.
The following 2 users liked this post by Stuart S:
MarkyUK (11-06-2020),
mosesbotbol (11-05-2020)
#40
