Wheel Question
Wheel Question
I spent a few hours on Sunday removing my wheels and then cleaning and polishing them with Mothers Cleaner and Polish. I also did the Alcon brake covers. After I was done I thought to myself I was wasting my time and money. The next time I use the cleaner, it is so strong the polish would be taken off. I am right? My thought was to put a polish on them so the break dust would not stick so bad.
Jim
P.S. I bought this new 12 volt Jack and Lug Wrench for $119.00 on line and it worked great, it made the job quick and easy.
Jim
Jim:
I use the Meguiars Hot Rim Brake Dust Barrier on my wheels. When I got the new Braelin BR02 wheels for my car last month I gave them multiple coats on the inside of the rims to keep them clean. Has worked well so far.
Then applied the Pinnacle Black Label Diamond Wheel Coating on the outside.....both have worked well, and are easy to clean. Nothing really sticks to the inside or outside surfaces. The wheel coating will go a long way for numerous applications.
Hope this helps other forum members and Jaguar owners.
LstFord (04-01-2014)
Best advise is a for good wheel brushes and sponges. Wheels are not going to stay clean, no matter what you do with OEM pads, but the right tools will expedite cleaning them. I like Meguiars Wheel Brightener and buy it by the gallon. Mixes 4 to 1. Can only be used on painted wheels. I have enough that I don't worry about running out when washing the car.
I don't think the wax lasts very long with wheel cleaning products.
Agree totally...I used the competitive product Pinnacle Black Diamond Wheel Coating before the wheels were even mounted.
I'm a believer that over time most wheel cleaners (regardless of the label stating it is safe on all finishes) can eventually wear away at the clear coat or wheels finish. I only use soap and water or meguiars cars wash mixed with water in a spray bottle. I have the appropriate brushes obtained from Autogeek and everything gets clean.
This is going to sound crazy, but here's a tip that works astonishingly well. Once you treat your wheels with a high quality coating (Pinacle / opticoat), wipe your wheels frequently with baby wipes. They are obviously gentle, but with the coating on the wheels, it cleans them up with virtually no effort. If dirt and break dust accumulates, however, a wheel cleaner may be required. Another household product good for a quick wheel clean is Swiffer pads.
You realy do Baby your car. I will try your tip as well as the others above.
Thanks for the responses.
Jim
hunter34
19
09-14-2022 11:09 PM
WTB[NorthEast]: X-Type Sport Wheels
Whitnessmouse
09-04-2015 11:09 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
