Wheel spacers installed - 2010 XK
So, after looking at a bunch of pictures from those who have done this I picked up a pair of 15mm spacers a member here who had an extra set. Figure I'll get another set of 15mm's but wanted to see what they'd look like before ordering the 2nd set in case I wanted a different size. Glad I did, I think the rear looks a bit off at 15, but I like the front. Thinking maybe 5 or 10 for the rear rather than 15. Whaddya'll think?
Before on left, after on right.
I haven't driven it much at all other than a quick lap around the block so can't comment on ride just yet. I moved both to the front wheels while I determine what size to go with for the rears.
The 15mm are Part #: 3035634 Trak + spacers. Easy install with the Kalimnos wheels as they have spots in the back of the wheel for the stock bolts to fit so no grinding or cutting is necessary.
so anybody could do it, any tire shops?
http://thmotorsports.com/hr/hr_trak_.../i-538973.aspx
I will appreciate any help from those with spacers, I do not feel good putting less in the rear than front. is it ok 15 mm front and rear? some did 20 and 5? so its a big difference?
I'm hesitant to do springs because I don't want to mess too much with the geometry and end up burning through the inside edge of tires. My two previous vehicles did that just in their stock setup.
If you've lowered what has your experience been with tire wear and what kind of springs did you install?
If you're worried about rubbing the front bumper on curbs etc, even a 15mm will help those wheels sit better in the arches, I think a few people here have 25mm drop, they can report their findings.
Here's mine:
Byte Me (06-10-2013)
As to lowering. The rear of the XKs do not have any camber adjustment. Mine is set up for about 1.25 degree negative at the rears which is plenty enough for street usage. If you lower the car, depending on the suspension geometry, you're liable to get more negative camber that will tend to wear the inside tire edges.
Albert
Looks like those are non-factory wheels? They stick out a bit too far in the back with the spacers. With my '08 XK with factory stock wheels I found 20mm front and 15mm rear to be the ideal setup for looks and handling. I initially installed 20mm on the rears as well but, they were too far out for my preference. If you have to use only 5 or 10 mm spacers, there is a good chance that you will have to cut (shorten) the factory wheel studs as they might touch the inside of your wheels.
Albert
Albert
Panthro (05-18-2020)
Albert
Albert
I will feel weird having less in mm spacers in the rear than front.
Do they carry the same spacers in 10 mm only?
This is a bad quality?
http://www.ebay.co.uk/itm/4-X-10mm-C...-/300820517472
What do you think about 10 mm all 4 wheels?
Thanks Albert, I have the same wheel and I believe they are factory wheels, or at least with the 10 xkr.
4 X 10mm CAST ALLOY WHEEL SPACERS SHIMS SPACER FITS JAGUAR XKR | eBay
As to the availability of 10mm spacers I could only recommend to get in touch with H&R. Their website lists the 15 mm for the '10 XKR applications. I do know that they make 5 and 10mm spacers, just not sure if for the XK specs.
2010 Jaguar XKR Applications || H&R Special Springs, LP
Albert
jagxk2008 (06-11-2013)
So,the newer wheels appear to come with a different offset compared to my '08. No problem.
Albert
Albert
The steering is "sharper", and the ride "feels" more planted. I do need to lower it with new springs. The ride should improve even more.
Evoking reported that when he put the springs on, his ride was firmer but not harsh, and that the "bouncy" ride was gone. I understand what he means with the "bouncy" reaction of the stock springs.
jagxk2008 (06-12-2013)
Albert
rscultho (06-12-2013)
