When charging, added LED-lights burn all the time!
Noticed something very weird. When I charge my battery, the added front LED-lights (been there years) light up, and they burn as long as I charge, no matter what I do. When I remove the charger, they turn off. What on earth? Somebody has done interesting wiring of said lights?
They are always on when I start the car, as intended, I guess. I did not install them.
Remember, I still have the battery problem (goes to 3 volts in two days if I don't use the car/charge the battery). Is there a connection? It used to work, for two years.
Hmmm I just swapped all 8 of my 5W daytime bulbs for LEDs. After I turn the lights off they stay on very dimly for a few minutes before going completely out. Capacitor discharge - quick and painless with filament bulbs; slow and brutal with LEDs.
Your situation seems different though. Check the ON/OFF switch for the lights?? Hahaaa
I thought mine went off after a few minutes as well but as it is Winter over here the garage is pitch black in the mornings and I have noticed that the LED's are still actually on but only very very faintly.
(Besides, when I took the extra LEDs away, now the light switch "auto" does not have any lights on when there is much daylight. Bad, because in here you must always have the head lamps on. Ugh.)
annamiata
12-08-2019 02:56 PM
Dell Gailey
04-16-2018 01:59 AM
Navionsam
05-21-2012 04:37 PM
