Yep I did look but wasn't going to take off insides to verify. Our cars are aluminum so does my battery ground cable attach to the body as in a steel bodied car or is it a loop? Can aluminum be used as ground?
As long as the factory provided ground studs are used, the aluminum body is a proper ground.
I am sure the ground stud material and staking process is carefully engineered, because using aluminum oxides can form ruining the connection if it is not designed properly.
