Where to plug in for smoke test, 4.2 supercharged?
You can unplug the vacuum pipe from the fuel rail pressure sensor and connect to that pipe. If you don't have secondary air injection, that same pipe has a free end at the top/front of the supercharger. You can pop off the check valve and plug into that free end.
Just remember to block off your air intakes.
I have a rough idle on start and whole my smoke machine is out for another car I want to smoke test my vacuum system on my XKR 4.2 to see if I can rule that out.
Where is the best place to plug in the smoke tester on this engine?
I'd start with a good solid seal on the TB (I used a solid rubber plumbing seal), then after getting all the ones that need real pressure, you can block off the lower ends of the intake piping with lower pressure (gloves and such) and check the various hose clamps between the MAFs and the TB.
Also, better to get a Jag compatible code reader than shotgun it. Need LTFT to settle on 0% + or - to test whether you got all the leaks and vacuum codes don't trigger until a 20% variance.
Some of the leaks don't show up until there's some solid pressure on the vacuum envelope. My '07 is 15 years old, and I found slight leaks on nearly every Oring. An off the Amazon shelf Oring kit solved all the leaks.
jaguars4r
09-01-2009 08:15 PM
