Where to wire in LED daytime running lights
My XF Sportbrake has them as standard fitment and I've successfully installed after market DRLs on a number of classics I own. I have the units and the correct relay, but I hate to admit I have failed to find where on the car I can easily connect to the car's loom. Even tried the fuse box unsuccessfully. I need to connect the relay to both a wire that is only, but always live when the ignition is on, and another that feeds the parking light circuit. Can anyone help please? Car is a '09 XK, one of the first 5L (ex UK, now in NZ).
I know I could use the headlights, but have found the LED DRLs to be more likely to be seen.
gmsclassics (01-27-2018)
I'd refer you to this thread started by Big Otter:
https://www.jaguarforums.com/forum/x...le-1-a-177558/
Thanks all, mine is an early 5L XK so no fitted DRLs and I would prefer not to have the dip beams on all the time.
Thanks to the wiring diagram and comments above I've found easy access to the sidelight wiring, and probably a place to store the relay, but exactly / physically where I can access an ignition live wire under the bonnet still eludes me. Can see it on the diagram but can't see where that actually is. Any further pointers welcome.
gmsclassics (01-30-2018)
Ditto. You should be able to find a relay that powers the o2 sensor heaters and use that as a trigger for your aftermarket light relay. I think the fans are always hot and just have a monitored speed signal that you don't want to mess with. There are also a couple connectors out by the bumper for ACC that may be hot on run. You'll need to probe around and see what works with a good volt meter.
Do you have the entire wiring diagram already? If not, you can download from here:
http://www.mediafire.com/?2ssiyne7ma1fs
And I don't know what model years X150 this applies to. It seems to line up with my 07, but may get you closer.
jaghelp.com: Jaguar XK Fuse location and ID
dustincarter
04-25-2021 08:58 AM
User 070620
10-14-2019 05:17 AM
User 070620
03-13-2014 07:55 PM
budsang1
33
02-13-2012 06:00 AM
