Whistling.........
So I emailed the vid I took to my dealer afternoon and also mentioned the TSB per Brutal. My service guy thinks it's sounds like low charge on the air. It does sounds like that but I think it's something different. Anyhoo.....he told me to stop by tomorrow and I will. I just hope it will while I'm there.
So I stopped by the dealer this morning and had the car sit for 15 min. and then restart it and the service guy did hear the whistle underneath the dash. He thinks it might be the servo that controls where the air flows to the vents but he won't be able to do anything unless it gets louder. You would think if he can hear the whistle which is not normal that he would be able to fix the servo but instead he said it needs to be louder before he can do anything about it.
Received 2,192 Likes
why didnt they just do the tsb to eliminate that as a cause..........friggen morons, why make it so hard........its a known issue and yes it does sound like low on freon. I would have done something on this issue rather than nothing. at least if you came back again it would have been with the understanding that this is what we're gonna do now and it may or may not work...and not make it another trip for what they could do now. At least if its not a normal sound as some things are after we investigate them
AND THIS IS 1 OF THE REASONS WHY MOMETUM JAGUAR WHERE I WORK, GOT JAGUAR'S "PRIDE OF JAGUAR" AGAIN
Exactly....wish they would have done something. I even mentioned and showed him the TSB when I was there this morning. I might try another dealer around here as I have 3 others that are between 30-50 min away. I just figured the one I bought the car, serviced and only 15 min away would be best. You would think they would want the biz eventhough it's still warranty work. THe service advisor actually "heard" the whistling in person but again said it needs to get worse before they can do something.
I took another video before I headed to the dealer this morning and again the whistling started right at 00:28 seconds again and this time lasted 'til :0030 seconds. I showed him both vids also.
This is from this morning (different from the vid above from yesterday)......
IMG_2699.mp4 video by lionheadxkr08 - Photobucket
OK here it is. Give your service rep the TSB number and it should be easy from there:
No: JTB00207
Issue: 1
Date: 31 AUG 2010
SECTION: 412
Air Conditioning Whistle Noise
AFFECTED VEHICLE RANGE: VIN B00001-onwards
CONDITION SUMMARY:
Situation:
A high-pitched whistle noise may be heard at low engine speeds and hot ambient temperatures. This noise may be caused by air flow within the air conditioning pipes.
Action:
In the event of a customer concern of the above, refer to the Repair Procedure outlined below to install a spacer in to the air conditioning pipe.
No: JTB00207
Issue: 1
Date: 31 AUG 2010
SECTION: 412
CONDITION SUMMARY:
Situation:
Action:
doctock993 (08-01-2011)
Thanks for posting this thread. I too was hearing this noise and thought it might be a vacuum leak. Checked everything and nothing showed up but still had it. Now that I know it's really nothing but a sound, I can live with it. My closet dealer is a moron anyway and it's a waste of time to ask them to fix anything.
#28
WildCat....thank for the info.
So someone I know told me to try this other dealer that he knows one of the mechanics there and so I made an appointment for next Thursday (just been busy this past week and early next). Hopefully they will be able to do something instead of sending me off on my merry way....hahaha.
frogdogfan: Looks like I'm 95% sure I'll be going tomorrow to Supercars Saturday in Bolingbrook (unless my buddy backs out). I'll probably won't be bringing the Jag or SL this time as I want to check to see how organized (I'm sure it is) before I bring one of the cars. My buddy with the 911TT will probably pick me up with is RRS SC and will be there around 10:00am. I know the show ends at 11:00am. Are you bringing the XKR to the show? If so....I'll try to look for ya.
#31
#34
Finally discovered what it is......the relay that runs the blower motor is going bad. It failed and no blower for A/C. Replaced the relay this weekend, and no noise all week.
So if your car is making that noise (at least 04 and up XJ8) your relay is going out and you will eventually lose your blower.
I am new to the forum, but will post a how to on replacing the relay with pictures since I just finished the job.
I hope this helps someone.
Chris
The following 2 users liked this post by clmurphy:
amcdonal86 (08-01-2013),
GhostriderXKR08 (08-01-2013)
#36
If it is like the XJ8 (and I assume it is similar) it will be behind the glove box. If you remove the glove box and see the main heating/cooling duct, below that duct will be the blower motor, and above the duct (with wires that lead to your blower) will be the relay.
Two phillips head screws and its out. As usual, the part is easy to remove, but getting to it is the pain.
I will try and get something up early next week as to how to get the glove box out (at least for the X350) and it will give the detail in pictures. I have taken the glove box out twice since buying the car in January, so I am getting good at it.
For us, we waited until the blower quit working to fix it (but she also has a van to drive). If you want to fix it before it quits, I would almost bet your problem is that relay. The parts for the XJ8 areC2C7090 orC2C39577 (the first is the newer version of the part). Not sure if yours will take the same part or not, but when you get it out you can compare it to those parts (I just looked on ebay and found one with a picture).
Let me know if that helps.
